Sb bronze distributor gear
#1066488
08/31/11 01:14 PM
08/31/11 01:14 PM
Posts: 383 Essex, Ont., Canada
Fishmarket
Essex, Ont., Canada
Any reason why I shouldn't buy the heavy duty distributor drive, take the steel gear off and press and pin a bronze gear from comp or lunati? This would save about $100 over the mopar bronze gear and shaft.
1972 Plymouth Cuda 340 4 speed
1971 Plymouth Road Runner 383 Auto
1970 Plymouth Duster /6 Auto
Re: Sb bronze distributor gear
[Re: Fishmarket]
#1066490
08/31/11 02:25 PM
08/31/11 02:25 PM
Posts: 15,487 Florida
scratchnfotraction
the lunati cams cores have a iron pressed on gear so the stock roller cam drives will work fine.
mines been in since 07' and I just swaped the roller cam to another 318.
also,you can save and use comp 901-16 spring with any of the lunati SB cams,
I run the 292/292 in a 360
the 60710 roller
and another one i forget the specs of,but in the 230/230 at 50 range
all with comp 901-16 springs and stock retainers/seals
all have .485/.485 lift
[Re: scratchnfotraction]
#1066491
08/31/11 03:11 PM
08/31/11 03:11 PM
Posts: 27,483 So Cal
autoxcuda
So Cal
Per the owner of Milodon, Milodon is coming out with SB Mopar bronze and steel gears of high quality material.
Suppose to be less $$ than the Comp stuff and little more than MP (but better mat'l).
I forgot if they are released yet, or will be soon. I heard he send some to Rob at Mancini. Call Milodon or Mancini to find out.
[Re: autoxcuda]
#1066492
09/02/11 12:32 PM
09/02/11 12:32 PM
Fishmarket
Essex, Ont., Canada
This is for a comp billet core. I was referring to the bronze gear only, that lunati sells... Manually putting a bronze gear on a heavy duty shaft to save money$$
Thanks for the info on the new gears!
