Re: OPEN 1" SPACER VS. 4-HOLE 1" SPACER
[Re: Labratt]
#1066119
08/30/11 10:12 PM
08/30/11 10:12 PM
Posts: 7,506 Az
Crizila
Az
I run them both. 1" 4 hole tapered Wilson in to a 1" open. They sit on a Victor 340. I know a 4 hole will improve the signal to the carb - could be better for street driveability. This is just my opinion, but the larger you can make the plenum and the farther you get the carb from the port runners ( within reason on a single plane manifold ) the more even the fuel distribution will be.
Fastest 300
[Re: rt66jim]
#1066123
08/31/11 12:36 AM
08/31/11 12:36 AM
Posts: 52,972 Romeo MI
MR_P_BODY
On my 416 with a PF950HP the 4 hole was worth .1 and 1.5mph. Victor W2 intake. Jim
Did you try any other types (open or stacking a open and a 4 hole)... also where did it pick up... was it in the 60'.... was that a 1" or 2"
[Re: Cab_Burge]
#1066125
08/31/11 10:21 AM
08/31/11 10:21 AM
BradH
Take both of them to the track and test them...
Yep... and they might work best w/ slightly different jetting, too.
Randy - Are you going back to the track over the Labor Day weekend?
[Re: Labratt]
#1066127
08/31/11 10:53 AM
08/31/11 10:53 AM
Posts: 17,846 S.E. Michigan
ZIPPY
S.E. Michigan
Definitely worth trying especially stacking them up, it's sort of a poor man's super sucker.
Mine picked up around 18hp with the right spacer combo, back when I had a street dominator 383 intake. But that was 3" worth of spacers which told me the manifold was lacking something.
The victor 383 intake was better to begin with and it only picked up 7hp with the addition of an open spacer..... a 4 hole spacer did absolutely nothing. It did not even change A/F ratio noticeably.
It's worth testing at somewhere like Jake's, so you can catch the little changes (ya know, 7, 8HP or whatever) when you come across em. It ain't much but if you got it, keep it! Myself I would have a hard time seeing 7hp on a timeslip but I am really not that good....
Rich H.
Esse Quam Videri
[Re: Dunnuck Racing]
#1066129
08/31/11 12:35 PM
08/31/11 12:35 PM
Posts: 7,506 Az
Crizila
Az
Personally, I think quantifying small improvements at the track is difficult at best. Just an hour between runs can cause DA, ambient air temp, track conditions, eng temps, to change your Et by a tenth. Thats where dyno testing shines. If I am looking for small improvements at the track, I rely on the MPH numbers before the ET #'s.
Fastest 300
[Re: BradH]
#1066130
08/31/11 12:41 PM
08/31/11 12:41 PM
Posts: 5,894 Florida
Locomotion
.....as well as pump squirter sizes!
[Re: Crizila]
#1066131
08/31/11 12:42 PM
08/31/11 12:42 PM
MR_P_BODY
MPH is what the engine is making(power wise) ET is what the chassis is doing
[Re: BradH]
#1066133
08/31/11 03:31 PM
08/31/11 03:31 PM
MR_P_BODY
Is that picture the Bigs-modified "950" you borrowed? That looks like an old 850 w/ the choke horn cut off and blended. Can you post a picture of the carb you're testing against my Demon?
You're not testing until the 23rd or 24th??? "Dude, where's my car(b)?"
I'm sure thats my 850 in the pic(looks like it) but he brought it back so I could put it on my new street engine
[Re: Crizila]
#1066134
08/31/11 09:31 PM
08/31/11 09:31 PM
Posts: 4,314 Prospect, PA
BSB67
Prospect, PA
This is true for me and my car. Although I track and record considerable information, I'm just not consistant enough. I always use a weather station, and repeat the change to confirm. I would say that half the time I cannot repeat the improvement that I thought I found.
