Cleaning out water passages in my 383 #1066021
08/30/11 07:19 PM
08/30/11 07:19 PM
minnarusta
TX9H6E4CUDA Offline OP
minnarusta
I just got done sealing up my 383 for my superbee. I took all the frost plugs out to replace them with brass units. Well I noticed there was some crud in the water passages. What is the best way to clean out the passages to try and make the best cooling for the car.
For the absolute best powder coating go to J.I.T powder coating, contact infomation is in my personal profile..
Re: Cleaning out water passages in my 383 [Re: TX9H6E4CUDA] #1066022
08/30/11 07:24 PM
08/30/11 07:24 PM
garden hose w spray nozzle & maybe your engine cleaning long handled brushes along w shop air
Re: Cleaning out water passages in my 383 [Re: TX9H6E4CUDA] #1066023
08/30/11 07:24 PM
08/30/11 07:24 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Pressure washer? (if the engine's not in the car)...
Re: Cleaning out water passages in my 383 [Re: DrCharles] #1066024
08/30/11 07:41 PM
08/30/11 07:41 PM
minnarusta
minnarusta
No the engine is sitting on the stand still but its all together. I just noticed some garbage in there (almost a clay like substance and some rust chunks) I just want to clean it out.
Re: Cleaning out water passages in my 383 [Re: TX9H6E4CUDA] #1066025
08/30/11 07:50 PM
08/30/11 07:50 PM
IMGTX Offline
IMGTX  Offline
Pull all the plugs and flush with a water hose.
You'll be fine but if you don't have the pans on it be careful where the water goes.
Re: Cleaning out water passages in my 383 [Re: TX9H6E4CUDA] #1066026
08/30/11 08:05 PM
08/30/11 08:05 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
This car and motor sat from 1987-2003 with the same coolant in my garage. I started it a couple times a year but never changed the coolant that I can remember. About 5 years after I started driving it again the core plugs rusted out.
I jerked the 340 out one Sat morning along with the tranny to replace all the core plugs. I used a pressure washer and got the inside of the block clean. There was a ton of junk in there.
Sun morning I put it all back in the car and was driving it that afternoon.
Felt real good about that.
Couple months later the motor won't turn over one morning. Found water in #5 cly, blew it out and the car started and ran fine. After a couple more times of this I knew I had a serious problem.
This picture was taken after I had pressure washed the motor clean inside and out. Then took the oil pan off to clean the inside of it out.
Jerked it out again a couple months later and ultimately found a crack in #5 cly. Shoot!
Then took another block I had and stuffed new pistons in it and put on Eddie heads I had for like 4 years. Never got around to using them until now. the block I had was still standard bore, Had to wait for pistons like a couple weeks or more because I wanted standard bore. I guess they don't sell many.
The new bullet, I built it at my race shop and brought it home, still running it today.
Good luck with yours.
Re: Cleaning out water passages in my 383 [Re: IMGTX] #1066027
08/30/11 08:09 PM
08/30/11 08:09 PM
minnarusta
minnarusta
Yep all the pans are on and sealed up. I just was wondering if I should use any cleaners or anything to knock the grime loose?
Re: Cleaning out water passages in my 383 [Re: TX9H6E4CUDA] #1066028
08/30/11 08:56 PM
08/30/11 08:56 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Garden hose and a long screwdriver or coat hanger wire. Once it's all sealed up and installed a gallon of vinegar in the cooling system cleans the rest up as a cheap cleaner/flush.
Don't be the exception.
Re: Cleaning out water passages in my 383 [Re: Supercuda] #1066029
08/30/11 09:14 PM
08/30/11 09:14 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
When people tear down an engine for a rebuild why not just have the block cooked. It doesn't cost very much have done and then it is done right. The new solvent used don't even eat up cam bearings like the old stuff did.
Re: Cleaning out water passages in my 383 [Re: MoparforLife] #1066030
08/30/11 09:32 PM
08/30/11 09:32 PM
Cincinnati, Ohio
Cincinnati, Ohio
I have always pounded out the cam bearings and had the block "hot tanked" with heated caustic cleaner. Still have access to one. This is the block for the above motor with Eddie heads.
Will a hi pressure parts washer get em this clean? Is that what there using nowadays?
Re: Cleaning out water passages in my 383 [Re: Challenger 1] #1066031
08/30/11 09:56 PM
08/30/11 09:56 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Do you think the cylinder wall crack could have been caused by the pressure washing? Or was it just age and corrosion... Maybe the hot-tank or garden hose would be safer?
Re: Cleaning out water passages in my 383 [Re: MoparforLife] #1066032
08/30/11 10:00 PM
08/30/11 10:00 PM
minnarusta
minnarusta
I would of but my engine is not rebuilt. It was rebuilt about 20 year ago and ran awesome when it was taken out. My friend and I inspected it and everything looked great inside so we regasketed it and upgraded it a little. I wanted to install brass plus so they don't rot out and noticed all the crap in there.
Re: Cleaning out water passages in my 383 [Re: TX9H6E4CUDA] #1066033
08/30/11 10:05 PM
08/30/11 10:05 PM
Cincinnati, Ohio
Cincinnati, Ohio
Heck yea, now is the time to clean it out of course and a garden hose will be fine along with a small diameter brush.
My cylinder in my block cracked from neglect during all those years of storage.imo And I'm sure I speed-ed it up by cleaning it up when replacing the core plugs.
If your block is to the point where a pressure washer can hurt it, it's junk anyway or will be soon like mine. lol
Re: Cleaning out water passages in my 383 [Re: Challenger 1] #1066034
08/30/11 10:15 PM
08/30/11 10:15 PM
minnarusta
minnarusta
Thanks for the help people ill get her done this week. I hope my block doesn't go bad but we will see.
Re: Cleaning out water passages in my 383 [Re: TX9H6E4CUDA] #1066035
08/30/11 10:33 PM
08/30/11 10:33 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Here in Md I cant find a machine shop with the old hot tank cooker thanks to the envierment people. Most shops just put the block in a water pressure type cleaner. It did not do as good a job as I liked on my 493 block so I took a long pick and went in the core plug holes as far as I could and cleaned out as much as I could. Then I washed it out with a hose and then with compressed air. Did a good job for me. Ron
Re: Cleaning out water passages in my 383 [Re: 383man] #1066036
08/31/11 12:31 AM
08/31/11 12:31 AM
About 20 yrs ago Doug Dutra the /6 guru used a percentage (not sure how much) of muriatic acid/water iirc & let it sit overnight & it got the insides as clean as the block several posts back. I do think the scale buildup even a smooth baked on coating of it inhibits heat transfer a fair amt
Re: Cleaning out water passages in my 383 [Re: 383man] #1066037
08/31/11 01:24 AM
08/31/11 01:24 AM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
Thank you envierment(enviroment) people! Now I can find rivers and streams to fish in when they were non-existant in Ohio before 1970 and clean water to drink..
Ron, Don't be too disheartened because when the EPA is dismanteled we'll be going back to cleaner living..
but back to the subject... why not seal it up mix up your own solution to let it cook for an hour? Drain cleaner and water? Pepsi please?
Re: Cleaning out water passages in my 383 [Re: TX9H6E4CUDA] #1066038
08/31/11 01:46 AM
08/31/11 01:46 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Muriatic acid. Use steel freeze plugs. With the block on the engine stand place one side upright and pour the contents in to the water passege. As soon as it hits the metal the solution will turn green. Let it sit for about 10 minutes then flush with water. The water dilutes the acid. Repaetr the same procedure on the other side of the block. Muretic acid is one of the chemicals I use in my pool. Be real carefull not to breath in the fumes. It's a sure trip to the ER.
Re: Cleaning out water passages in my 383 [Re: dart4forte] #1066039
08/31/11 04:42 AM
08/31/11 04:42 AM
Dart4forte did you use it straight
Re: Cleaning out water passages in my 383 [Re: 52savoy] #1066040
08/31/11 05:02 AM
08/31/11 05:02 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I wasn't knocking them but I guess it sounded that way. I understand why they do what they do. I guess I just hate that my blocks dont get cleaned as good as they used too. Ron
