Brake Pedal switch Wiring Question #1066005
08/30/11 06:17 PM
08/30/11 06:17 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Looking for some help on my wiring questions. On my brake pedal the switch has 2(connectors) Do I have these oriented properly pink closer to the pedal? Cant find these wires on the diagram?
1966 Charger 383 4 speed (Black with Red interior)
1973 Cuda 340 4 speed (Lemontwist)
1972 Corvette
Re: Brake Pedal switch Wiring Question [Re: 19cuda73] #1066006
08/30/11 06:20 PM
08/30/11 06:20 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
doesn't matter. it works either way. All the swtich does is complete the circuit once the pedal is depressed
Re: Brake Pedal switch Wiring Question [Re: gtx6970] #1066007
08/30/11 06:43 PM
08/30/11 06:43 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Thanks Bill, you can now see the true level of my electrical knowledge.
1972 Corvette
