Page 9 of 14 1 2 7 8 9 10 11 13 14
Re: Subframe connectors, which way shoul [Re: Molloy] #1061
01/25/04 12:45 PM
01/25/04 12:45 PM
Hey Malloy, do you have any pics of INSIDE the car, of the connector running through the floor?
On edit: Guess I was posting as you were!!!!
Re: Subframe connectors, which way shoul [Re: Molloy] #1062
01/25/04 12:47 PM
01/25/04 12:47 PM
USA
Molloy Offline
Molloy  Offline
USA
'nother pic from the top:
Re: Subframe connectors, which way shoul [Re: Molloy] #1063
01/25/04 12:48 PM
01/25/04 12:48 PM
USA
Molloy Offline
Molloy  Offline
USA
trans x-member weld:
Re: Subframe connectors, which way shoul [Re: Molloy] #1064
01/25/04 12:49 PM
01/25/04 12:49 PM
That is what my Mustang looked like when I installed my connectors on it. Good job there.
Re: Subframe connectors, which way shoul #1065
01/25/04 12:50 PM
01/25/04 12:50 PM
USA
Molloy Offline
Molloy  Offline
USA
Thanks. Where's Pearland in Houston?
Re: Subframe connectors, which way shoul [Re: Molloy] #1066
01/25/04 12:53 PM
01/25/04 12:53 PM
SE side, near Clear Lake, Friendswood. I graduated high school your kneck of the woods, Langham Creek, '90, off of Barker Cypress and FM 529!
Re: Subframe connectors, which way shoul #1067
01/25/04 01:01 PM
01/25/04 01:01 PM
USA
Molloy Offline
Molloy  Offline
USA
Zoiks! That's like 45-115 mins drive from here, depending on traffic.
Ever go to the sat cruise at I-10 and hwy 6 (west side)?
Re: Subframe connectors, which way shoul [Re: Molloy] #1068
01/25/04 01:39 PM
01/25/04 01:39 PM
Back in the day when I had a "street" car, we would. We would cruise Westheimer from the 610 loop all the way out to Cinco Ranch, PASSED Hwy 6! We would all meet up in Deer Park on Center Street, and make our way out there. We did that for many years, until the cops got real bad, run us off, and then we all pretty much took our cars off the street, and made them "strip" only cars. I raced in the Fun Ford events for many years (93-00) and was in the process of re-doing my Mustang, got CRAZY with the money I spent on it, and decided I wanted a street car again, so now I have a Mopar!
Re: Subframe connectors, which way shoul #1069
01/25/04 09:00 PM
01/25/04 09:00 PM
Great posts , after reading all about how frame conectors are a small gain in stength in the body twisting department ,and that you realy need a cage ,and that its the cross bracing of the cage is what stops the twisting etc ,etc ,etc,this got me thinking . Ok guys here are a few ideas to throw around that may (or maynot) help without installing a cage.Ok behind the back seat of most Mopars is 'X' bracing already ! This rear deck area behind the seat is also reinforced on convertables yes ! So tie this into the subframes for extra strength, you could use tube and could hide it behind the seat for an almost stock apperance .Same could be done up front with a little thought. Well what do ya think ?Could work.
Re: Subframe connectors, which way shoul #1070
01/26/04 12:14 PM
01/26/04 12:14 PM
USA
Molloy Offline
Molloy  Offline
USA
I was thinking about boxing the same cross braces (behind the seat) that you are referring to. I think tying them into the rear subframe is also an excellent idea! My 71 RR chassis is picked clean so now is the perfect time.
Re: Subframe connectors, which way shoul [Re: Molloy] #1071
01/26/04 01:17 PM
01/26/04 01:17 PM
541 slobovia
A990 Online content
A990  Online Content
541 slobovia
RLB, Malloy
Ive been thinking about that very thing too, but on the fron end! lol
What if a diagonal brace was put across the firewall and core support somehow. It seems the engine is the prime source of torsional stress. hmmm. Tying the seat brace sounds good too
-Ken
Re: Subframe connectors, which way should we [Re: Molloy] #1072
01/26/04 06:10 PM
01/26/04 06:10 PM
New England
Q5_Ed Offline
Q5_Ed  Offline
New England
Good info....
WANTED : ...A New Sponsor or Winning Lottery Ticket 69 A12 road runner ,Q5, post coupe, 4 speed, former Drag car restored to "Driver" condition in the early 90's, Showing some Patina. SS/E Track Record Holder 1980 10.40 @ 130mph
Re: Subframe connectors, which way shoul [Re: A990] #1073
01/26/04 08:51 PM
01/26/04 08:51 PM
Actually on a B or E body you could probably tye the frame rails in the engine bay against the fire wall to the top of the plenum in a "V" shape and then from that center point on the fire wall two stut braces like Mustangs to just above the suspention ( shocker ) pad. ! Just a thought.
Re: Subframe connectors, which way shoul #1074
01/28/04 09:08 PM
01/28/04 09:08 PM
Hey , have you guys run out of ideas ?
Re: Subframe connectors, which way should we #1075
01/29/04 06:14 AM
01/29/04 06:14 AM
Clarkston,MI
Todd_DesMarais Offline
super street
super street
Clarkston,MI
1UglyFish (YES it is,what lake did that northern come from?) I'm not sure what your getting at, but a proper weld is stronger than the pieces it joins. the "overheated area" I think you are refering to is an annealed or heat treated area so to speak. it looks bluish in color and is approx 1/4 to 5/16" wide. this is for a gmaw (mig) welded joint on .083-.125 material. this area is slightly brittle compared to the base metal, but acts as a transition to the hardened weld.
the best way to attach two pieces is to plug weld through the base material. this is what I, and a few others have done. for maximum strength, the total contact area of the two materials needs to be figured out, then a 50% split of each to be welded. make sense??
My welds on the bottom of ZIPPY'S car don't look all that good, and I'm not proud of their show appeal, but they have great penetration.
have I ever said I hate welding on my back (inside joke)
aduC' 47 IIeredevleB 66 383 etilletaS 66 DTC 0053 MAR 50 "ssenlli latnem a dna ,ybboh a neewteb enil enif a si ereht"
Re: Subframe connectors, which way should we [Re: Quicktree] #1076
01/29/04 12:05 PM
01/29/04 12:05 PM
is this cranking hp or rear wheel hp ?
Re: Subframe connectors, which way should we [Re: Todd_DesMarais] #1077
01/29/04 12:43 PM
01/29/04 12:43 PM
I get it now! 50% through welds as opposed to 100% involved welds. Makes perfect sense and Malloy's pics really gave me good ideas.
Hey Malloy, what type of welding equipment do you use? What do you recommend if using 110VAC service? I hear Lincoln is excellent, but I don't know where to find a good used one.
Great link, this should go into the archive!
Re: Subframe connectors, which way should we [Re: Todd_DesMarais] #1078
01/29/04 12:53 PM
01/29/04 12:53 PM
Oh yeah. That was my first (and only) experience with ice-fishing. We were at the N end of Stony Creek in 1996. It was only about a 12-14" and he went back for a swim. But he was my inspiration for the passion I have for Cudas. The one I'm building now is going to be hideously ugly and stupid strong. I'm going to build a cruiser that I can beat the hell out of and really enjoy. The paint is going to be scaled and colored like a real Barracuda. I can't wait for it to be done, but thanks to MOPARTS, it's coming right along.
Re: Subframe connectors, which way should we #1079
01/29/04 03:36 PM
01/29/04 03:36 PM
USA
Slider Offline
super gas
Slider  Offline
super gas
USA
Ok, I followed this through three (more than that?!) recessiatations, and I have a question. When cutting the top of the SFC to match the contour of the floor pan (like pete did), how do you get the pattern of the contour onto the SFC to cut it? Thanks!
And, excellent work and thread!
�Hunt down those Chevies and Fords and crush �em like bugs!� ~ Tom Hoover
(O=o=====o=O)
Re: Subframe connectors, which way should we [Re: Slider] #1080
01/29/04 05:23 PM
01/29/04 05:23 PM
541 slobovia
A990 Online content
A990  Online Content
541 slobovia
Slider, a contour gauge will do it
You probably could borrow one, they are very handy. Bodyshops use them a lot
Ken
