TIMING CHAIN TENSIONER 4 BIG-BLOCK............. #1065832
08/30/11 11:18 AM
08/30/11 11:18 AM
State of confusion
Thumperdart Offline OP
State of confusion
Years ago a guy I worked on a project with Butch Lightfelt,and he utilized a production tensioner and fit it to big-blocks to help w/chain stretch curious if any of you run one or know what I could adapt to my 400 block. Thankxxx..............
Re: TIMING CHAIN TENSIONER 4 BIG-BLOCK............. [Re: Thumperdart] #1065833
08/30/11 02:23 PM
08/30/11 02:23 PM
Cab_Burge Online work
Cab_Burge  Online Work
Buy a good timing set and forget about it loosing tension Keeping the chain tight does not stop the stretching, which makes the cam timing change BTW, Butch was always cheap
Re: TIMING CHAIN TENSIONER 4 BIG-BLOCK............. [Re: Cab_Burge] #1065834
08/30/11 04:12 PM
08/30/11 04:12 PM
State of confusion
State of confusion
I just figured if worked for small-blocks, it would work for me. Butch is a VERY interesting man for sure.
