2005 pt cruiser gurling in coolant tank #1065447
08/30/11 12:19 AM
08/30/11 12:19 AM
Central Illinois
Don_440 Offline OP
Don_440  Offline OP
Central Illinois
My wifes car,we bought it new , now has 145,000 miles on it ,no problems till tonight coming home,never had any issues with the car. while arriving home ,shut car off,notice this noise,open hood ,this thing is perking like a old coffee pot.temp. guage stayed in middle the whole time,elecrtic fan is working,runs like a swiss watch.let it cool down ,coolant level low,appox, about 3/4 gal ,did not any drips under car except what came out of overflow tank,any ideas?
Re: 2005 pt cruiser gurling in coolant tank [Re: Don_440] #1065448
08/30/11 02:18 AM
08/30/11 02:18 AM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
Fan may not be running on both speeds.
Re: 2005 pt cruiser gurling in coolant tank [Re: Don_440] #1065449
08/30/11 02:37 AM
08/30/11 02:37 AM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
3/4 of a gallon is A LOT of coolant loss. Fill it up and keep a V E R Y close-eye on it! ....and bring some spare 50/50 mix with you uNtil it is fixed.
You could have a leaking water pump or a toasted head-gasket.
Re: 2005 pt cruiser gurling in coolant tank [Re: dOoC] #1065450
08/30/11 03:11 AM
08/30/11 03:11 AM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
Check the radiator cape and the thermostat. I've gone through two caps on mine and when I did my water pump and timing belt, I found that the thermostat was broken. It's also very hard to get all the air out of the system once it gets in. Find a shop with an Airlift system to bleed it.
