Max Wedge Intake gaskets. #1065201
08/29/11 06:00 PM
08/29/11 06:00 PM
Westbury, NY
bumps440 Offline OP
super gas
bumps440  Offline OP
super gas
Westbury, NY
What are you guys using for intake gaskets on Max Wedge sized ports. I am not impressed with either the Mr gasket intake, or the Fel Pro.
Im not familiar with the Indy gaskets.
clue me in. OR is there anything else available? or should I say readily available.
Re: Max Wedge Intake gaskets. [Re: bumps440] #1065202
08/29/11 06:16 PM
08/29/11 06:16 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I use the Indy gaskets so far no problems.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Max Wedge Intake gaskets. [Re: bumps440] #1065203
08/29/11 06:18 PM
08/29/11 06:18 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
The Superformance on left, STD Fel Pro max Wedge on right. I stock both, as some guys still want Fel Pros, but as you can see, there's no comparison. The Superformance has a much larger surface area to stabilize the gasket.
RIP Monte Smith
Re: Max Wedge Intake gaskets. [Re: CompWedgeEngines] #1065204
08/29/11 09:44 PM
08/29/11 09:44 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
Hughes Engines also sells a nice gasket for the MW port
Re: Max Wedge Intake gaskets. [Re: bumps440] #1065205
08/29/11 11:46 PM
08/29/11 11:46 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
I've been using the same intake gaskets from INDY for 12 years now. I just put a thin layer of grease on them, and they always come off like the day I installed them.
Jeff
Re: Max Wedge Intake gaskets. [Re: bumps440] #1065206
08/30/11 02:09 AM
08/30/11 02:09 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
what dont you like about the Mr Gasket intake? that was the best of the ones i've tried for the price.
Re: Max Wedge Intake gaskets. [Re: JERICOGTX] #1065207
08/30/11 05:23 AM
08/30/11 05:23 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Indy has .030 & .060 ... the fit seems real nice! I believe indy sell a smaller & bigger port MW gaskets and I have the big port ones... never tried the superformance for intakes yet but so far I like the superformance line...
Mopar Performance
Re: Max Wedge Intake gaskets. [Re: moparniac] #1065208
08/30/11 08:22 AM
08/30/11 08:22 AM
Westbury, NY
bumps440 Offline OP
super gas
bumps440  Offline OP
super gas
Westbury, NY
OK thanks for all the comments and info. From what I see I like the Superformance and the Indy gaskets. The Mr Gaskets are too thin around the ports, and so are the Fel Pros.
I like the fact that the Indys are available in a few thicknesses.
didnt get the CNC heads yet so will have to see whats the best fit. Soon. this week I hope.
Re: Max Wedge Intake gaskets. [Re: bumps440] #1065209
08/30/11 08:29 AM
08/30/11 08:29 AM
tboomer Online work
tboomer  Online Work
Bumps...Did you buy the Victor heads?
Re: Max Wedge Intake gaskets. [Re: tboomer] #1065210
08/30/11 08:53 AM
08/30/11 08:53 AM
Westbury, NY
bumps440 Offline OP
super gas
bumps440  Offline OP
super gas
Westbury, NY
Yes.... just waiting for them to arrive...
CNCd with 2.25 intake valves 1.81 exhaust.
Re: Max Wedge Intake gaskets. [Re: bumps440] #1065211
08/30/11 08:56 AM
08/30/11 08:56 AM
tboomer Online work
tboomer  Online Work
Nice!! Where did you get them? And please post some pics and flow numbers when they arrive!!
Re: Max Wedge Intake gaskets. [Re: bumps440] #1065212
08/30/11 10:18 AM
08/30/11 10:18 AM
Syracuse,NY
Syracuse,NY
FYI...Superformance are available in both .031 and .062 as well.
RIP Monte Smith
Re: Max Wedge Intake gaskets. [Re: CompWedgeEngines] #1065213
08/30/11 10:33 AM
08/30/11 10:33 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Thanks Todd, was just going to mention that
I'd also like to add that these gaskets will not wick fluids (fuel in this case) into them which brakes down the binders that hold the material together for more durability. Will also maintain excellent bolt torque so you don't have to babysit your intake bolts
Are they the best? Give Competition Wedge a call, try them & let me know
Re: Max Wedge Intake gaskets. [Re: CompWedgeEngines] #1065214
08/30/11 03:56 PM
08/30/11 03:56 PM
Westbury, NY
bumps440 Offline OP
super gas
bumps440  Offline OP
super gas
Westbury, NY
Thanks to both for that info. I will give them a try, still waiting on the heads.
I like the idea of multiple thicknesses, make fitting easier.
I will have to mill my intake surfaces a lot anyway, but may still help.
thanks.
