Re: Max Wedge Intake gaskets.
[Re: bumps440]
#1065202
08/29/11 06:16 PM
08/29/11 06:16 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
I use the Indy gaskets so far no problems.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: bumps440]
#1065203
08/29/11 06:18 PM
08/29/11 06:18 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
The Superformance on left, STD Fel Pro max Wedge on right. I stock both, as some guys still want Fel Pros, but as you can see, there's no comparison. The Superformance has a much larger surface area to stabilize the gasket.
RIP Monte Smith
[Re: bumps440]
#1065212
08/30/11 10:18 AM
08/30/11 10:18 AM
CompWedgeEngines
Syracuse,NY
FYI...Superformance are available in both .031 and .062 as well.
RIP Monte Smith
[Re: CompWedgeEngines]
#1065214
08/30/11 03:56 PM
08/30/11 03:56 PM
Posts: 1,170 Westbury, NY
bumps440
super gas
super gas
Westbury, NY
Thanks to both for that info. I will give them a try, still waiting on the heads. I like the idea of multiple thicknesses, make fitting easier. I will have to mill my intake surfaces a lot anyway, but may still help. thanks.
