egt's after a pass
#1065082
08/29/11 01:26 PM
08/29/11 01:26 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
what kind of EGT is normal under WOT?
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
Re: egt's after a pass
[Re: Dunnuck Racing]
#1065085
08/29/11 02:02 PM
08/29/11 02:02 PM
sixpackgut
Charleston
a friend just dropped a valve in his boat. he has a egt on the number 1 cylinder right by the exhaust port which is the exhaust valve that broke.
i'm thinking his egt's were in the 1300 range
540 bbc.
[Re: sixpackgut]
#1065086
08/29/11 02:54 PM
08/29/11 02:54 PM
Posts: 52,972 Romeo MI
MR_P_BODY
540 bbc.
1300 is about normal BUT it make a difference whether the reading is 1" off the edge of the flange or 2" and so on.... at work(when I was) I tried to get a standard of 1" so we could ALL talk the same numbers.... now days I use the EGT just for balancing the intake runners and I put the end of the probe right in the center of the port dead nuts on 1"... I use a set of calipers to set it
[Re: hysteric]
#1065088
08/29/11 07:58 PM
08/29/11 07:58 PM
MR_P_BODY
Mr P body can you elaborate on how you use the egt's to tune intake runners? Also have you done work with smallblock DP's like the stealth and rpm and M1 sp?
Hysteric
Start with the carb square jetted... run the car and read what every cyl temp is(like I said ALL of my probes are exactly in the same place on all of the cyl) and if some are running hotter than others its running leaner so its a matter of opening those runners up to get more fuel OR closing down the others... I try to get them all within about 10*-15* on all of them... if I could use 8 O2 sensors I would but they really block the flow when your talking primary tubes... I also use 1/16" probes instead of 1/8 or even 1/4 probes
