egt's after a pass #1065082
08/29/11 01:26 PM
08/29/11 01:26 PM
Charleston
sixpackgut Offline OP
Drag Week Mod Champion
Charleston
what kind of EGT is normal under WOT?
Re: egt's after a pass [Re: sixpackgut] #1065083
08/29/11 01:36 PM
08/29/11 01:36 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Be specific as to where you are reading. (e.g.-in the collector or at the port exit.) If you speaking of your specific application from what I vaguely know of it I'd guess (<)1450*F at the port. Ideally, you could balance port-to-port EGT's with jetting or intake manifold manipultaion. I'd taylor your AF first and whatever your EGT is...it is If you know what I'm saying. Because spk adv. has a large effect.
Re: egt's after a pass [Re: HardcoreB] #1065084
08/29/11 01:47 PM
08/29/11 01:47 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Exactly.
EGT's are good for cylinder to cylinder variations,not for dialing in A/F or spark advance. There are a lot of variables affecting the numbers.
Keith
Re: egt's after a pass [Re: Dunnuck Racing] #1065085
08/29/11 02:02 PM
08/29/11 02:02 PM
Charleston
Charleston
a friend just dropped a valve in his boat. he has a egt on the number 1 cylinder right by the exhaust port which is the exhaust valve that broke.
i'm thinking his egt's were in the 1300 range
540 bbc.
Re: egt's after a pass [Re: sixpackgut] #1065086
08/29/11 02:54 PM
08/29/11 02:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
540 bbc.
1300 is about normal BUT it make a difference whether
the reading is 1" off the edge of the flange or 2"
and so on.... at work(when I was) I tried to get a standard
of 1" so we could ALL talk the same numbers.... now
days I use the EGT just for balancing the intake
runners and I put the end of the probe right in the
center of the port dead nuts on 1"... I use a set
of calipers to set it
Re: egt's after a pass [Re: MR_P_BODY] #1065087
08/29/11 07:44 PM
08/29/11 07:44 PM
Aus
hysteric Offline
hysteric  Offline
Aus
Mr P body can you elaborate on how you use the egt's to tune intake runners? Also have you done work with smallblock DP's like the stealth and rpm and M1 sp?
Hysteric
Re: egt's after a pass [Re: hysteric] #1065088
08/29/11 07:58 PM
08/29/11 07:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Hysteric
Start with the carb square jetted... run the car and
read what every cyl temp is(like I said ALL of my probes
are exactly in the same place on all of the cyl) and
if some are running hotter than others its running
leaner so its a matter of opening those runners up
to get more fuel OR closing down the others... I
try to get them all within about 10*-15* on all of
them... if I could use 8 O2 sensors I would but they
really block the flow when your talking primary tubes...
I also use 1/16" probes instead of 1/8 or even 1/4
probes
