A body K frame differences? #1064665
08/28/11 09:09 PM
08/28/11 09:09 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
I have a K frame made for a 426 hemi with all the mounts and all. The K frame says on it 68-69 A body. I got it at the Indy mopar swap meet this spring.
My question is:
What is the difference in a 68-69 A body K frame and say a 70 or 71?
I was wandering incase I wanted to use it to build a 70/71 nostalgia prostock duster or demon since everybody else is putting them in 68 barracudas and darts.
Re: A body K frame differences? [Re: maxie] #1064666
08/28/11 10:54 PM
08/28/11 10:54 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I don't believe there is any major differences between the '68/9 and the '70/1/2. The '67 had a different mount for the idler arm though.
Re: A body K frame differences? [Re: slantzilla] #1064667
08/28/11 11:56 PM
08/28/11 11:56 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
70-71 K-frames had a coin welded on the drivers front, I am not aware of any other differences.
JB Rhinehart, Realist
A-Body's RULE!
Re: A body K frame differences? [Re: Rhinodart] #1064668
08/29/11 01:24 AM
08/29/11 01:24 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Any A-body k-member from 67-76 can be bolted into any 67-76 A-body. The major differences are the single stud 67 idler arm and the change to spool mounts in 1973. Slanty, small block, and big block k-members were all different, too. There were other changes to the sway bar mounting in 1973 and the center link.
Re: A body K frame differences? [Re: maxie] #1064669
08/29/11 02:42 AM
08/29/11 02:42 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
My question is:
Did you buy it from Al Debevec?
Yes the 68-72 are all dimensionaly the same.
This is actually a 68 /6 K-member Troy welded into a Hemi super stock k-member with a S/S kit in AZ. That was before Al advertised his.
Pics from a few hours ago from Troy's garage. These are the first TTI A-body hemi headers the media took pics of. TTI supposedly changed the design slightly to accomodate 4spd's. Check with TTI on that...
Re: A body K frame differences? [Re: autoxcuda] #1064670
08/29/11 12:46 PM
08/29/11 12:46 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
I can't remember his name. I will look at his business card. I thunk he is out of Minnesota. He gives you the piece to weld in the right shock tower and I got the steering column from him.
