Re: tranny pressures - what to look for?
[Re: boscosis]
#1064284
08/28/11 10:58 AM
08/28/11 10:58 AM
Posts: 16,923 NC
440Jim
NC
I've got Carl Munroe's book for reference I just hoped that someone could tell me what to expect if something is wrong.
Carl's book has some good instructions and pictures of the pressure measurement points, pages 207-209. The only thing I will add is that with your manual valve body, the line pressure at 1000-1500 rpm should be at least 120 psi (90 psi stock), and depending on the design it could be 140 or more.
I think if the pressure is low it is likely a ring/seal issue, or if basically zero pressure the pump drive tangs could be broke off.
The feeling of two gears at once is tough. While you are testing with the trans in the car, the simple things like shifter cable adjustment are worth doing. Even disconnecting the shifter cable and putting the lever in each gear by hand and then checking how it moves the car.
[Re: boscosis]
#1064285
08/28/11 12:40 PM
08/28/11 12:40 PM
Posts: 2,407 Ambridge, Pa.
rickraw
Ambridge, Pa.
need more specifics. if were in 2 gears it won't move. i agree with 440jim, check ur cable for detent. ur trunion should lift out of the selector arm with no pressure on it, meaning u have perfect gear selecting. line pressure is checked on the center 1/8 pipe plug. i have 180#-1st, 160#-2nd&3rd. if u don't get a reading on the center plug, u will have to hookup 2 quages, 1 on the front plug & on the rear of the case. stay safe, seeya.
[Re: boscosis]
#1064286
08/28/11 04:55 PM
08/28/11 04:55 PM
Posts: 25,757 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The OP needs to explain why he thinks it's in two gears at once....the problem might not be pressure related.
