A12 Engine #1064041
08/27/11 06:44 PM
08/27/11 06:44 PM
Indy
biged1932 Offline OP
Indy
Hello, How can I tell if I have a real 69.5 440 6 pak engine ?
Thanks for the help.
Re: A12 Engine [Re: biged1932] #1064042
08/27/11 06:49 PM
08/27/11 06:49 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
From many threads in the past...(search for them with google search if you are not sure)
By matching the partial VIN on it to a known sixpack car.
Re: A12 Engine [Re: biged1932] #1064043
08/27/11 06:50 PM
08/27/11 06:50 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
It needs to have a vin stamped on it from the known production run.
Re: A12 Engine [Re: T2R9] #1064044
08/27/11 06:56 PM
08/27/11 06:56 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
You know the old saying about a picture being worth a thousand words and all...
Re: A12 Engine [Re: OzHemi] #1064045
08/27/11 07:12 PM
08/27/11 07:12 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
Right-Click, Save-As.. Got it!
Re: A12 Engine [Re: OzHemi] #1064046
08/27/11 10:42 PM
08/27/11 10:42 PM
Indy
Indy
Thanks, Thats some funny stuff too !!!
Re: A12 Engine [Re: biged1932] #1064047
08/28/11 02:31 AM
08/28/11 02:31 AM
you will have to tear it apart after you look at the casting date on the block and the sequence number stamped onto the oil pan rail, if the block was cast after 6-21-69 ( I think that is the date the production lines where stopped in 1969 for production line cars ) it is probally not a real 1969 1/2 six pak block. If it was cast before March of 1968 in may not be a real 6 pak block either, maybe so though knowing how Chryler used what they had when they needed it. I found out a long time ago to never say never when it comes to production cars What are the numbers stamped onto the right oil pan rail and what is the casting date on your motor?
