correct sheen for radiator #1063905
08/27/11 02:02 PM
08/27/11 02:02 PM
wellington ohio
68-scatpack-rt Offline OP
In thin ice
In thin ice
wellington ohio
hello all. what is the correct sheen for the radiator and metal shroud on a 68 coronet? what kind of paint are you guys using?
thanks, rob
unions....the folks who brought you the weekend!
Re: correct sheen for radiator [Re: 68-scatpack-rt] #1063906
08/28/11 07:59 AM
08/28/11 07:59 AM
wellington ohio
In thin ice
In thin ice
wellington ohio
anyone?
Re: correct sheen for radiator [Re: 68-scatpack-rt] #1063907
08/28/11 09:55 AM
08/28/11 09:55 AM
VT
greasyspider Offline
VT
Eastwood sells a Radiator paint. The sheen is gloss black, however regular 'ol rattle can black is not the best choice as is can hold heat. The eastwood stuff is a thinner, lighter gloss black that still allows heat transfer.
Re: correct sheen for radiator [Re: greasyspider] #1063908
08/28/11 12:19 PM
08/28/11 12:19 PM
MoreParts Offline
MoreParts  Offline
That eastwood stuff is good. Probably the very best product of theirs overall.
Re: correct sheen for radiator [Re: MoreParts] #1063909
08/28/11 12:50 PM
08/28/11 12:50 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
i've got a 68 radiator unrestored and it looks just about flat black, maybe it started out low or semi gloss??? i don't think they were gloss black.
Re: correct sheen for radiator [Re: ademon] #1063910
08/28/11 01:35 PM
08/28/11 01:35 PM
SE Pa.
LimeliteAero Offline
SE Pa.
the heat in the engine compartment area definetly knocks the gloss out of the finish. Im not sure about the original finish on the radiators but it dosent take long to make semi gloss turn into flat black under the hood.
I wouldnt use gloss as its just too shiney for my taste but I would use the semi gloss and be prepared to repaint in a few years.
Re: correct sheen for radiator [Re: LimeliteAero] #1063911
08/28/11 01:38 PM
08/28/11 01:38 PM
Kirkland, Washington
Pacnorthcuda Offline
Huh? Gloss holds up just fine under heat. I paint radiators semi gloss though, and they are still semi gloss years later.
Re: correct sheen for radiator [Re: Pacnorthcuda] #1063912
08/28/11 02:35 PM
08/28/11 02:35 PM
wellington ohio
In thin ice
In thin ice
wellington ohio
thanks guys!
Re: correct sheen for radiator [Re: Pacnorthcuda] #1063913
08/29/11 10:03 AM
08/29/11 10:03 AM
SE Pa.
SE Pa.
let me in on what paint youre using....everything I paint dulls down quite a bit.
Re: correct sheen for radiator [Re: LimeliteAero] #1063914
08/29/11 10:11 AM
08/29/11 10:11 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
You can paint them semi gloss but the were gloss from the factory. Cheap gloss that was not near as good of paint as today's formulas.
Eastwoods is the best choice out there.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: correct sheen for radiator [Re: MOPARMIKE69] #1063915
08/29/11 01:32 PM
08/29/11 01:32 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: correct sheen for radiator [Re: DPelletier] #1063916
08/29/11 05:36 PM
08/29/11 05:36 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
I used to paint mine semi gloss but all the hi end cars are done in gloss so I switched years back to gloss and am very happy with the outcome. Oh and Eastwood as stated is the way to go. Ron
Re: correct sheen for radiator [Re: 68-scatpack-rt] #1063917
08/30/11 11:02 AM
08/30/11 11:02 AM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
anyone?
Re: correct sheen for radiator [Re: RJS] #1063918
08/31/11 12:17 PM
08/31/11 12:17 PM
SE Pa.
SE Pa.
if the radiators should be gloss from the factory, I would think Glen-Ray would be supplying his units in gloss. AFAIK he is "the" radiator man.
Re: correct sheen for radiator [Re: LimeliteAero] #1063919
09/01/11 11:55 AM
09/01/11 11:55 AM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Compared to vintage magazine roadtest pictures, I would say lots of restored cars do not have enough gloss on the radiators
Re: correct sheen for radiator [Re: LimeliteAero] #1063920
09/01/11 01:49 PM
09/01/11 01:49 PM
DPelletier Offline
DPelletier  Offline
I'll put my money on the OE gold cars and survivors over whatever "the" radiator man is doing.
Re: correct sheen for radiator [Re: DPelletier] #1063921
09/01/11 02:09 PM
09/01/11 02:09 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Gloss. Flat black rads are one of the first things I notice under the hood (oh and those replacement rad caps and flexible rad hoses), Ugh.
Sheldon
Re: correct sheen for radiator [Re: RUNCHARGER] #1063922
09/01/11 02:45 PM
09/01/11 02:45 PM
DPelletier Offline
DPelletier  Offline
Sheldon
Hood? what is this "hood" thing you speak of?
Re: correct sheen for radiator [Re: 68-scatpack-rt] #1063923
09/01/11 02:51 PM
09/01/11 02:51 PM
PA
BTTG Offline
BTTG  Offline
PA
Not to hijack,but.... what about an A/C condenser? Was/should the same paint be used for it?
Re: correct sheen for radiator [Re: DPelletier] #1063924
09/01/11 03:06 PM
09/01/11 03:06 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Just went out and looked at the 5000 mile survivor, untouched A12 bee. Gloss, no ifs, ands, or buts, about it.
69 Road Runner vert
69 GTX hard top
70 Hemi Cuda vert
