correct sheen for radiator
#1063905
08/27/11 02:02 PM
08/27/11 02:02 PM
Posts: 1,144 wellington ohio
68-scatpack-rt
In thin ice
In thin ice
wellington ohio
hello all. what is the correct sheen for the radiator and metal shroud on a 68 coronet? what kind of paint are you guys using? thanks, rob
unions....the folks who brought you the weekend!
Re: correct sheen for radiator
[Re: LimeliteAero]
#1063911
08/28/11 01:38 PM
08/28/11 01:38 PM
Posts: 21,827 Kirkland, Washington
Pacnorthcuda
the heat in the engine compartment area definetly knocks the gloss out of the finish. Im not sure about the original finish on the radiators but it dosent take long to make semi gloss turn into flat black under the hood.
I wouldnt use gloss as its just too shiney for my taste but I would use the semi gloss and be prepared to repaint in a few years.
Huh? Gloss holds up just fine under heat. I paint radiators semi gloss though, and they are still semi gloss years later.
[Re: LimeliteAero]
#1063914
08/29/11 10:11 AM
08/29/11 10:11 AM
Posts: 2,636 Nashville, TN
MOPARMIKE69
Nashville, TN
You can paint them semi gloss but the were gloss from the factory. Cheap gloss that was not near as good of paint as today's formulas. Eastwoods is the best choice out there.
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
[Re: RJS]
#1063918
08/31/11 12:17 PM
08/31/11 12:17 PM
Posts: 6,584 SE Pa.
LimeliteAero
SE Pa.
I used to paint mine semi gloss but all the hi end cars are done in gloss so I switched years back to gloss and am very happy with the outcome. Oh and Eastwood as stated is the way to go. Ron
if the radiators should be gloss from the factory, I would think Glen-Ray would be supplying his units in gloss. AFAIK he is "the" radiator man.
[Re: DPelletier]
#1063924
09/01/11 03:06 PM
09/01/11 03:06 PM
MOPARMIKE69
Nashville, TN
I'll put my money on the OE gold cars and survivors over whatever "the" radiator man is doing.
Just went out and looked at the 5000 mile survivor, untouched A12 bee. Gloss, no ifs, ands, or buts, about it.
