Aftermarket RB block help??
#1063789
08/27/11 10:01 AM
08/27/11 10:01 AM
Posts: 625 Florida-West Coast
Thor500
Florida-West Coast
Long story short, what I thought was a blown head gasket turned out to be a split cylinder wall. The motor is a 500" stroker with less than 100 runs, 14:1, Indy -1 cnc heads, with Jesel pushrod oiling. The more searches I do the more confused I get. I would like to just transfer The parts I have to the new block, this will never be a maximum effort 572, just trying to build a solid ,long living bracket motor. Are the Mopar Performance blocks good, are they available? Any input is appreciated, The motor will be assembled by a reputable shop, not sure who yet. There is'nt much in the way of Mopar oriented machine shops in the Tampa Fl. area, unless someone knows of one. Sorry this is so long, you guys are the best, thanks in advance.
Re: Aftermarket RB block help??
[Re: MR_P_BODY]
#1063792
08/27/11 10:33 AM
08/27/11 10:33 AM
Posts: 3,104 Wheels up, MO
nhramark
Wheels up, MO
Don't waste another dime on that stock block. I got my Megablock in 2003 and there are more choices now. Call Indy (or an Indy dealer), call Koffel, call Keith Black. There are others as well, do your research. Then BUY the AFTERMARKET block that makes sense for you.
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image]
9.100 @ 150 mph
5.780 @ 120 mph
[Re: Thor500]
#1063794
08/27/11 10:56 AM
08/27/11 10:56 AM
Posts: 1,973 SoCal
jake4cars
SoCal
call Dan Dvorak @ Dvorak machine in Gainesville, I am sure he will have something. Joey
[Re: Thor500]
#1063796
08/27/11 11:10 AM
08/27/11 11:10 AM
Posts: 16,931 NC
440Jim
NC
...turned out to be a split cylinder wall.
What were the cyliner wall thickness numbers from the sonic test? The availability of the MP blocks (World Products) comes and goes. Since you want to use your pistons (4.3xx"), you will need the smaller bore blocks and sometimes only the larger bore (~4.5") are available. Koleno is an option, slightly more expensive from what I have seen posted.
[Re: Thor500]
#1063797
08/27/11 06:07 PM
08/27/11 06:07 PM
Posts: 2,091 Delray beach, Florida
Performance Only
what bore size is your current block?
machine shop owner and engine builder
[Re: Dunnuck Racing]
#1063801
08/28/11 09:26 AM
08/28/11 09:26 AM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
If all other cylinders have good wall thickness, and a mag check of the whole block looks good, (main bearing webbing) I might chance sleaving it and adding block fill and AL caps or girdle. But tally up the cost and compare to an after market block and see what comes up. Best route is KB aluminum in my opinion, but thats' me.
