Re: NHRA rules?
[Re: ksj]
#1063468
08/26/11 07:22 PM
08/26/11 07:22 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I've been on drag week a couple of times... you will need a helmet even in the DD class... other than that they check all your normal stuff on the car the first time... lights, turn signals and all that stuff so its street legal ..... helmet is all you need
Re: NHRA rules?
[Re: ksj]
#1063469
08/26/11 07:28 PM
08/26/11 07:28 PM
Radiator overflow canister of some sort. A small cola bottle with a hole drilled in the cap works great. Make sure you don't run antireeze at the track!
Re: NHRA rules?
#1063471
08/26/11 09:58 PM
08/26/11 09:58 PM
MR_P_BODY
Sorry but alot of these are street cars and they do run anti freeze
Re: NHRA rules?
[Re: NANKET]
#1063474
08/27/11 07:48 AM
08/27/11 07:48 AM
MR_P_BODY
How about a battery hold down, seat belts, and 2 throttle return springs? What wheels do you run on there, do you need long wheel studs? The tech guys can be sticklers if they want. Also a good idea is a torque strap on the engine so you don't break the motor mount with that 4 speed. Question, at what ET with a 4 speed are you required an aftermarket bellhousing? Another one to check on before going.
Dont need any of that in a 14 second car
Re: NHRA rules?
[Re: Evil Spirit]
#1063475
08/27/11 07:55 AM
08/27/11 07:55 AM
MR_P_BODY
That's what petcocks and drain pans are for - to drain and save the antifreeze to be used on the street - not on the track.
Never seem anyone drain before each day...and no one ever said anything about anti freeze... hell, how many cars go down any track with it.... tons... yeah it would be nice if they didnt... but thats life
Re: NHRA rules?
[Re: MR_P_BODY]
#1063476
08/27/11 11:11 AM
08/27/11 11:11 AM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
Never seem anyone drain before each day...and no one ever said anything about anti freeze... hell, how many cars go down any track with it.... tons... yeah it would be nice if they didnt... but thats life [/quote)
More and more tracks have and enforce no antifreeze rules. They usually don't enforce it on the newer, daily driver stuff, but the last several times at Milan they've checked my car. And any track that doesn't do a good tech, I don't want to race at, anyways - it's not worth having some clown too lazy to have the proper equipment slam into my car because his car didn't have the proper equipment.
Granted, the "spectacle" Pinks may not be the best indicator of race knowledge, but I agreed with Rich on the show where he started DQ'ing cars for A/F after several cars pizzing up the track. It's both a safety issue for the car and a time issue for cleanup thats easily avoided.
Free advice and worth every penny... Factory trained Slinky rewinder.........
Re: NHRA rules?
[Re: Evil Spirit]
#1063477
08/28/11 05:37 PM
08/28/11 05:37 PM
They jumped on my "driver" 'Cuda about the battery hold down studs not being large enough.
