Re: Good way to estimate how much to mill an intake?
[Re: BradH]
#1063430
08/26/11 01:46 PM
08/26/11 01:46 PM
Posts: 5,160 Texas
dannysbee
Texas
Sorry Brad I can't help you but now might be a good time to answer a question I have as well. Would it be better to cut the heads or the intake? You have to make two cuts on the intake so it should not be any more expensive to cut both heads.
Getting old just means you were smarter than some and luckier than others.
[Re: BradH]
#1063432
08/26/11 01:53 PM
08/26/11 01:53 PM
Posts: 2,091 Delray beach, Florida
Performance Only
if you have half a bolt hole showing with no gaskets, shim it up until you are covering the bolt hole. you'll need to cut that amount plus 80%-85% of the thickness of the gasket you intend to run.
machine shop owner and engine builder
[Re: Performance Only]
#1063433
08/26/11 02:19 PM
08/26/11 02:19 PM
Posts: 553 Kentucky
clovis
Kentucky
Just went through the same. I could not get the intake between the heads. I wound up putting extra head gaskets on until I got the intake to fit. Once I knew the deck increase needed to make it fit, I calculated the intake cut. So in my case, it took two extra gaskets .040 (each), .080 total to make it fit without a gasket. I took the .080 x 1.23 to get .0984 or basically .100. I wanted to use a .060 intake gasket, so by the math I needed .160 total-I decided to just go .150. Since the heads had been milled and the intake side had never been cut, I cut the intake side of the head .050, and then I cut the intake itself .100. Everything fit perfectly with the gasket after the cut. All the bolts run in by hand.
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
