Good way to estimate how much to mill an intake? #1063429
08/26/11 01:39 PM
08/26/11 01:39 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
What have you found to be a good way to estimate how much to mill an intake manifold? In some cases I've been able to use different thicknesses of gaskets to figure out how much should be cut, but this is a little different.
The intake is uncut and will barely fit (i.e. allow the bolts to be installed) the block / head combination even w/o any gaskets 'tween the heads and intake. Looking down both the bolt holes and the manifold runners shows the intake is obviously shifted up too high.
Given the cost to mill the intake, it will quickly become "cost ineffective" to guess-timate cutting off XXX, fitting it up again and sending it back again to the shop for another round of machining. So, any suggestions on coming up w/ a fairly accurate measurement for an initial (and hopefully only) cut is appreciated. - Brad
Re: Good way to estimate how much to mill an intake? [Re: BradH] #1063430
08/26/11 01:46 PM
08/26/11 01:46 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Sorry Brad I can't help you but now might be a good time to answer a question I have as well. Would it be better to cut the heads or the intake? You have to make two cuts on the intake so it should not be any more expensive to cut both heads.
Getting old just means you were smarter than some and luckier than others.
Re: Good way to estimate how much to mill an intake? [Re: BradH] #1063431
08/26/11 01:50 PM
08/26/11 01:50 PM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
It should be a simple right angle trig equation, u know the angle of the heads,now measure the distance it is off from the hole.
now u have 1 leg of the triangle and a angle, u should be able to figure it out from there.as in the post below account for the gasket and crush
Re: Good way to estimate how much to mill an intake? [Re: BradH] #1063432
08/26/11 01:53 PM
08/26/11 01:53 PM
Delray beach, Florida
P
Performance Only Offline
P
if you have half a bolt hole showing with no gaskets, shim it up until you are covering the bolt hole. you'll need to cut that amount plus 80%-85% of the thickness of the gasket you intend to run.
machine shop owner and engine builder
Re: Good way to estimate how much to mill an intake? [Re: Performance Only] #1063433
08/26/11 02:19 PM
08/26/11 02:19 PM
Kentucky
clovis Offline
clovis  Offline
Kentucky
Just went through the same. I could not get the intake between the heads.
I wound up putting extra head gaskets on until I got the intake to fit. Once I knew the deck increase needed to make it fit, I calculated the intake cut.
So in my case, it took two extra gaskets .040 (each), .080 total to make it fit without a gasket. I took the .080 x 1.23 to get .0984 or basically .100. I wanted to use a .060 intake gasket, so by the math I needed .160 total-I decided to just go .150. Since the heads had been milled and the intake side had never been cut, I cut the intake side of the head .050, and then I cut the intake itself .100.
Everything fit perfectly with the gasket after the cut. All the bolts run in by hand.
'75 Plymouth Duster
Phase I 451 906/590/2-660 10.75/126
Phase II 451 Stage VI/590/1050 9.82/135
Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: Good way to estimate how much to mill an intake? [Re: Performance Only] #1063434
08/26/11 02:38 PM
08/26/11 02:38 PM
Az
Crizila Offline
Crizila  Offline
Az
Do you mean shim up the manifold until the bolt hole in the head is centered on the manifold bolt hole?
Fastest 300
Re: Good way to estimate how much to mill an intake? [Re: Crizila] #1063435
08/26/11 04:21 PM
08/26/11 04:21 PM
P
P
no, the problem is that his manifold sits to high. by how much he didn't really say. but if half of the bolt hole in the head is all that shows, he can raise the intake with shims or gaskets until it's raised an equal amount. then use that thickness to decide how much to cut so the manifold sits down lower afterwards.
Re: Good way to estimate how much to mill an intake? [Re: Performance Only] #1063436
08/26/11 04:39 PM
08/26/11 04:39 PM
Westbury, NY
bumps440 Offline
super gas
bumps440  Offline
super gas
Westbury, NY
IMO
it is always better to cut the cylinder heads. that way the manifold remains universal and can be used on any other head and engine combination. if you cut the manifold you are limiting it to be used ONLY with that engine.
For every .010 taken off the deck surface .012 needs to be removed from the manifold surface.
Re: Good way to estimate how much to mill an intake? [Re: BradH] #1063437
08/26/11 05:57 PM
08/26/11 05:57 PM
BradH Offline OP
BradH  Offline OP
Thanks for the input.
Re: Good way to estimate how much to mill an intake? [Re: BradH] #1063438
08/26/11 06:18 PM
08/26/11 06:18 PM
ill
dennismopar73 Offline
ill
idono, i put intake on dry, then take feeler gauge front to back, side to side, top to bottom, then go to my machinist, he cuts it i put it on, done
Re: Good way to estimate how much to mill an intake? [Re: Performance Only] #1063439
08/26/11 06:41 PM
08/26/11 06:41 PM
Az
Crizila Offline
Crizila  Offline
Az
Got it. Thanks. I was looking at it backwords.
Fastest 300
Re: Good way to estimate how much to mill an intake? [Re: bumps440] #1063440
08/26/11 08:23 PM
08/26/11 08:23 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Depends on which engine...
Read more in my article here:
http://victorylibrary.com/mopar/intake-mill.htm
Boffin Emeritus
