Rookie Needs Help With Racing Seat Install
#1063411
08/26/11 01:16 PM
08/26/11 01:16 PM
Posts: 757 Northern VA
bulletpruf
Northern VA
Fellas -
So I took the factory buckets out of my street/strip car (it's a ferd fairlane - like a b-body, but slower!) a few months ago and sold them. Wasn't able to get it done before I moved to Georgia (Columbus) so I've been using a milk crate for a seat when I need to move the car.
Could use some advice on a good seat and install procedures. Car is a street/strip with a cage; no long trips planned so I don't need cushy buckets. I have Kirkey's in my 71 Javelin road race car, and those are fine. Thinking about going with a pro-street/race Kirkey with a cover.
Question is how to mount them. Is there an easy way to do this or will there be a fair amount of fabrication any way I go? I was hoping to see some sort of bracket that would weld to the floor and the seat would bolt on to. Also would like to have adjustability, at least on the driver's seat. I'm 6'4" so anyone else driving it will likely have to move the seat up.
FYI - I have a fair amount of tools, including a Miller mig welder, but welding skills aren't great; I need more practice.
Thanks in advance for any input!
Scott
Please Check Out My YouTube Channel for Vintage Musclecar and Truck Rescues and Builds -- https://www.youtube.com/@THEBULLETPROOFGARAGE/videos
Re: Rookie Needs Help With Racing Seat Install
[Re: bulletpruf]
#1063415
08/26/11 11:30 PM
08/26/11 11:30 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Fellas -
Scott
I would get some 1/4" flat stock and weld up some brackets... when you set in the seat make sure the front of it is angled up enough to support your thighs so its comfortable... the back and the bottom should be close to 90*... I just mounted the seats in my Rampage with a tube chassis
[Re: cgall]
#1063417
08/30/11 07:46 PM
08/30/11 07:46 PM
bulletpruf
Northern VA
Thanks for all the info, fellas.
Scott
