Re: Could I please see your home made shop tools?
[Re: Bigcube]
#1063344
08/26/11 02:28 PM
08/26/11 02:28 PM
Posts: 7,506 Az
Crizila
Az
Rt to Lt: Oil pump primer - on top of dist. wrench. Modified degree wheel. Carb stand ( 2 small holes on rt bottom corner are tapped for air bleeds - for drilling ). Head rotisserie stands - drilled to accomidate many different heads.
Fastest 300
[Re: Crizila]
#1063346
08/26/11 09:04 PM
08/26/11 09:04 PM
Posts: 16,928 NC
440Jim
NC
I made this transmission tool. It is to compress the front clutch springs of a 727 Torqueflite so you can change the seals, springs, etc. Pretty simple, but something is needed to do it!
[Re: Crizila]
#1063348
08/26/11 10:30 PM
08/26/11 10:30 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I have so many home made tools I couldnt even think how many... when I'm out there tomorrow I'll look around... I just made a bunch of tools for my buddy so he could build his 700R4 GM trans
[Re: MR_P_BODY]
#1063350
08/27/11 12:14 AM
08/27/11 12:14 AM
Posts: 7,506 Az
Crizila
Az
A few engine building tools: Most are obvious. Cam install tool can be used with single bolt cams ( SB as shown ) using the aluminum adaptor which has a 7/16" threaded rod on the cam side or that section can be unbolted ( 3 bolts ) and it can be used with 3 bolt cams and dowel pins. Handle is about 15" long and has a "T" on the other end ( not in pic). Angle tool on top of the block is an easy way to see if the head port side angle matches the manifold angle. Cam checking lifter is nothing more than 2 gutted hyd lifters with a piece of threaded pipe jamed between them. Adjustable positive stop on #1 hole.
Fastest 300
[Re: Mcode69]
#1063353
08/27/11 08:12 AM
08/27/11 08:12 AM
Posts: 399 metro detroit
turner
metro detroit
tubing bender for 1" black pipe or similar diameter material, bender made with scrap parts and powered by muscle...we have another at work thats gets used and abused by 60 other millwrights and works awesome
[Re: John_Kunkel]
#1063355
08/27/11 03:45 PM
08/27/11 03:45 PM
Posts: 7,506 Az
Crizila
Az
I've got pump pullers similar to yours. What's the horse-shoe looking thing for on the upper right side?
Fastest 300
