Cuda window channel sealing "tape" ? #1063217
08/26/11 07:53 AM
08/26/11 07:53 AM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
I need to know what to use to relace the original sealing type "tape" on my Cuda's side window channels see pic. Also does anyone have a diagram to help with installation.....it's been awhile. Does the tape have a layer between the channel and trim, as well as the body and channel? And is it the same material?
Re: Cuda window channel sealing "tape" ? [Re: UCUDANT] #1063218
08/26/11 08:59 AM
08/26/11 08:59 AM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
70-71
(2) rolls of 1/8"x7/8" black poly foam to seal between the weatherstrip channel and the roof,
(2) rolls of 1/16"x3/4" dark gray soft foam with adhesive on one side to seal the weatherstrip channel to the drip rail.
In 72 Mopar changed the "dark gray soft foam tape" to 1/8" thick from 1/16". I recently changed my kits to cover 70-74 and have been just using the thicker tape.
Re: Cuda window channel sealing "tape" ? [Re: UCUDANT] #1063219
08/26/11 10:00 AM
08/26/11 10:00 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
I used the tape in 71TA's kit. It worked great on my 73. It had the same type tape on it originally.
Craig
Re: Cuda window channel sealing "tape" ? [Re: denfireguy] #1063220
08/26/11 10:39 AM
08/26/11 10:39 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
My 73 used the adhesive backed tape on both areas. Between the body and the drip rail trim AND between the drip rail trim and the weatherstripping channel. I also used the DMT kit and it worked great.
Re: Cuda window channel sealing "tape" ? [Re: burdar] #1063221
08/26/11 02:01 PM
08/26/11 02:01 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Guys how much if any should the top wrap around and into the channel? It goes under the channel/trim?
Re: Cuda window channel sealing "tape" ? [Re: UCUDANT] #1063222
08/26/11 02:43 PM
08/26/11 02:43 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I still have my original top. I was able to remove it in one piece. It was trimmed off right at the edge of the drip rail. It did not wrap around it at all. That's how I trimmed my new top. I originally had some material wrapped around the edge but the drip rail trim didn't want to go on very smoothly. It went right on once I trimmed the excess.
Re: Cuda window channel sealing "tape" ? [Re: burdar] #1063223
08/26/11 08:52 PM
08/26/11 08:52 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
Re: Cuda window channel sealing "tape" ? [Re: NV69B7RR] #1063224
08/27/11 09:18 AM
08/27/11 09:18 AM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
I found a piece of my original top under the molding when I removed the existing aftermarket top. It doesn't really mean anything. Here is what I found in the reproduction 72 factory service manual
Re: Cuda window channel sealing "tape" ? [Re: UCUDANT] #1063225
08/27/11 09:21 AM
08/27/11 09:21 AM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Sorry but it's a PDF file and not easily document export friendly...
Re: Cuda window channel sealing "tape" ? [Re: UCUDANT] #1063226
08/29/11 10:30 AM
08/29/11 10:30 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
It is worse than that, it is a 'protected' PDF. You can cut and paste from PDF if it is unprotected.
One huge tip on applying the vinyl. Follow the adhesive directions to the letter. I rushed mine, the VOCs in the glue did not disipate enough before I laid it down and months later, the off gassing had created bubbles under the vinyl all over the roof. It will be replaced in a few weeks.
Craig
