RACE TRAILER QUESTIONS
#1063033
08/25/11 09:11 PM
08/25/11 09:11 PM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
Hope this can stay in the race section... I currently pull a 24ft enclosed two axle trailer with a GVW of 9800lbs with a 2500 Megacab Dodge and has a GVW of 9000lbs. I'm looking at a 40ft gooseneck enclosed three axle with a GVW of 15000lbs. Before I commit i'd like to know what legally I need to pull it. IE License, Length, weight and how much difference in pulling from a bumper to a gooseneck. I appreciate any input. Mike
Founder and CEO of the Central Valley Mopar Drag Pack
Re: RACE TRAILER QUESTIONS
[Re: mikeysmopars]
#1063035
08/25/11 09:26 PM
08/25/11 09:26 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
start your info search at you states DMV not here. Mainly because so many states are represented by our members whose laws will have some minor differences. States usually don't mess with correctly registered vehicles if from another state.
home of the Sox and Martin Hemi Duster
[Re: MIKES_DUSTER]
#1063036
08/25/11 09:27 PM
08/25/11 09:27 PM
Posts: 5,160 Texas
dannysbee
Texas
I have a CDL and it is my understanding under 26000 gvw truck and trailer combined you would not require a CDL.
Getting old just means you were smarter than some and luckier than others.
[Re: HEMIFRED]
#1063038
08/25/11 09:34 PM
08/25/11 09:34 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
most I checked 31,000 was the trigger for CDL
It's 26,001 in Floriduh
Rickster
[Re: 340Bird]
#1063041
08/25/11 09:46 PM
08/25/11 09:46 PM
Posts: 1,402 State of Corruption
camdog440
State of Corruption
From the California commercial DMV website... A commercial vehicle is a motor vehicle or combination used for hire to transport passengers or property or which: Has a gross vehicle weight rating (GVWR) of 26,001 pounds or more Is designed, used, or maintained for carrying more than 10 passengers, including the driver Tows a vehicle or trailer, which has a GVWR of 10,001 pounds or more Transports hazardous materials, which requires placards Tows any combination of two trailers or vehicle and trailer Cali DMV
[Re: mikeysmopars]
#1063043
08/25/11 10:10 PM
08/25/11 10:10 PM
Posts: 43,124 Bend,OR USA
Cab_Burge
I have a 10,00 GVW 24 FT Pace tag car trailer(wieghs 8600lbs loaded) and a 14,500 GVW 34 fifth wheel travel trailer that weighs 11,000 lbs hooked to the truck. The fifth wheel pulls a lot better than the tag does, especially in the wind. I have a 2006 3500 Ram 4 door 4WHDR long bed single wheel, it stops well with either trailer.
[Re: mikeysmopars]
#1063045
08/25/11 10:42 PM
08/25/11 10:42 PM
Challenger 1
Cincinnati, Ohio
I have done what your considering. I started with a 26' tag enclosed, pulled it with a 87 ramcharger, like 5 miles each way to Edgewater, then used a 2500 87 dodge truck with a 360. It was not enough truck for that 26' trailer going through the mountains, burnt valves in the 360 plus it was a pretty hairy ride. Then bought a new 93 3500 4 wheel truck, not a dually. It did a great job with a 454 gas motor. Then put a ball in the bed and bought a 40' gooseneck trailer enclosed. It towed better and easier than the 26' tag. I think your 2500 truck should be alright for a while, depending on where you tow. Then got a 99 dually new with a 454 and 456 gears. It would pull great at about 6 miles to the gal. Then bought a 49' trailer and used the dually for about a year, it was way too much trailer for my dually. It did have 3 engines,3 trans, hundreds of clutch plates, couple hundred gals of water and fuel. Then I bought the toterhome, it'll pull almost anything. You don't need a CDL because we are racing for fun. There's no sponsor name on my trailer. Recreational use does not require CDL, no matter how big and heavy your rig is. In Ohio no special license is needed, saddle up and go!! I have driven coast to coast and have never stopped at a weigh station and have never been stopped for speeding because I don't speed.
[Re: mikeysmopars]
#1063046
08/25/11 10:55 PM
08/25/11 10:55 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Most states tend to vary from one another so start with your state and any state that you think you might travel through.... here in Mich our rules are way different
[Re: Bigcube]
#1063047
08/25/11 11:04 PM
08/25/11 11:04 PM
Posts: 248 Ohio
aquamist60
Ohio
Anything I've heard is a goose neck or 5th wheel tows much easier than a tag. With the Mega Cab you have a short box, make sure the overhang on the trailer won't hit the cab on sharp turns or backing up and I'd say go for it!
I haven't personally checked into it since I pull a tag, but a friend of mine was looking to pull a 5th wheel with a short bed. He said he found a 5th wheel "slider" that slid to the back around corners then came back going straight. Don't know the make, but it seemed like a good option.
[Re: Challenger 1]
#1063048
08/25/11 11:20 PM
08/25/11 11:20 PM
mikeysmopars
fresno ca
Thanks Gary, Kick a$$ set up btw. The trailer i'm looing at is very much like that. My truck has a cummins and has more power than i need and I take Everything with me when I go Racing. The biggest problem is I cant take my Golfcart, The 40 footer would really be nice especially when we do the Vegas race and Sanoma Ca Gettin around those places you need a cart and its too big to get in my current setup.
[Re: aquamist60]
#1063049
08/25/11 11:23 PM
08/25/11 11:23 PM
MR_P_BODY
Draw Tite and some of the other big companies make them
[Re: Get-X]
#1063051
08/25/11 11:28 PM
08/25/11 11:28 PM
mikeysmopars
fresno ca
Believe me if I could get it in,on it, apart and reassemble I would. As i said when I go racing I dont go to have issues and throw in the towel. I bring a couple scooters and everything in my shop. I think thats why all my buddies stopped bringing there own tools!
