Universal Spark Plug Wires, how do you do it?
#106289
08/16/08 11:27 PM
08/16/08 11:27 PM
Posts: 227 Scottsdale, AZ
Cudalord
Scottsdale, AZ
I just purchased a set of universal plug wires and I am going to install them tomorrow. Any pointers or tips before I start this? I tried this once and it didn't work out so well, but I'm giving it another shot because the custom wires never seem to fit. What's the process that you all use? The more details, the better. Here are a few questions I came up with.... 1. Do you put the wire through the boot, then crimp it and pull it back into the boot? Or is it vise versa? 2. Do you plug in to all the spark plugs, then determine the length by the best route? 3. I have the MSD Part number 5553 and it came with a plastic crimper, will that be sufficient? 4. The wires are pre-stripped, and showing what looks like a black braided wire. Do I need to strip that down any further, or can I just bend it back and crimp on the fitting and be done with it? Thanks in advance. And, just to clarify, I'm looking for advice on how to build/tailor my universal wires, please don't respond with "get the custom set by "****", part# "****". I have tried a few custom sets and they never fit right...
Re: Universal Spark Plug Wires, how do you do it?
[Re: Cudalord]
#106290
08/17/08 12:10 AM
08/17/08 12:10 AM
Posts: 70,126 Here
DirectSubjection
Tacohead. The First and Only
Here
Push the wire thru the boot first (I use a lubricant), then strip, then crimp, then pull the wire back to seat the end in the boot. Wayyyy easier that way.
All plugs installed, looms in place, one wire at a time.
Can't say - never used it. I bought a pliars special that has an awesome pulg wire crimper built in.
I never worked with MSD wires so I don't know - their instructions should say. As I recall on Accels its just strip, fold, crimp. My Taylor 10.4's I last did were a whole different story.
Ride eternal, shiny and chrome
[Re: DirectSubjection]
#106291
08/17/08 12:26 AM
08/17/08 12:26 AM
RapidRobert
I with DS on 1&2. I have no exp with #3 & on #4 the ends are stripped of insulation down to the tiny black core wire in the center? If the length is PERFECT then slide on a boot(I use silicone spray for lube) & crimp on the metal terminal & install but the length on those prefabbed deals is never exactly where I want it so I cut it to where it's just right.
[Re: Cudalord]
#106293
08/17/08 09:40 AM
08/17/08 09:40 AM
Posts: 3,378 Rancho Cordova, CA
Exit1965
Rancho Cordova, CA
I have done those specific wires, I do not remember if it's necessary to cut the black wire back any, just fold it over and see if it's the right length. In my own experience, using the "multi angle" boots, it seemed to be easier to do the crimping then use the rigidity of the terminal to push the boot on. Rather than trying to push a rubbery wire through another piece of rubber. If my memory serves, the MSDs do not come with any lubricant but it definitely helps (the Taylors I bought, after cooking some MSD boots, came with lube). This is all bringing up terrible memories of very sore thumbs for days after installing spark plug boots.
[Re: Cudalord]
#106294
08/17/08 11:54 AM
08/17/08 11:54 AM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
I've done a bunch of them too (MSD and others) since all my cars needed them custom made as well.. What everyone said is right on..the plastic crimper will work in a vise, no prob if you don't have the hand held ones (or the metal crimp dies for a vise they used to come with, I have a few sets of both kinds) The wires might be pre-stripped on the dizzy end, but once you cut them to your length, you'll have to redo them anyways.. Oh, and when you slide the boot on first off, use a lube like Taco said, I just use spray silicone
[Re: 1fastrunner]
#106297
08/17/08 02:44 PM
08/17/08 02:44 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
Write down the firing order, where the wires are in the cap, and where they are on the engine. Remove all the old wires, noting which is the shortest and which is the longest. On a small block, shortest is usually #8, longest is usually #1. Start with the shortest new wire, install all the wires on the plugs. Route them so they fit the looms, 5 and 7 are apart, and leave enough slack at the Dist. so you can remove the cap. Also leave enough on the plug end so that you can remove them easily. You do not want them tight end-to-end! Cut each wire with ~.75 inch extra. Strip that 3/4 inch leaving the center conductor. Spray silicone into the dist. boot(with your finger over the wire hole), and then dribble the extra spray from the boot onto the wire. Slip the boot onto the wire. If they are tough, slide a pair of needle-nose pliers inside to stretch them some. Apply lube again if you do this. Slide the boot a couple inches up the wire for working room. This part is why you want to buy the crimping pliers. If you don't, you have to remove the wire and go over to the bench vise here. Fold the conductor over the side, and place the terminal over it, holding it in place. Crimp the terminal tightly. Install the terminal tightly into the cap. Make sure it locks. Now slide the boot down the wire onto the cap. Not fully, because it will pull the terminal out. You have to 'burp' it as it goes on, too. Repeat for the rest. Remember to leave enough slack so that the cap can be removed! Double check for clearance around hot items, make sure they clear the throttle/kickdown, and steering or other moving parts. Drive until hot, then recheck boots on the cap.
