Re: Special Fuel Inlet Tool Available for Sixpack?
[Re: floyd]
#1062817
08/25/11 05:29 PM
08/25/11 05:29 PM
Posts: 25,933 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Nothing special about that wrench, it's a common 15/75 degree open-end wrench, all the tool makers offer them.... probably even Harbor Freight.
The Holley inlet fitting is 1".
[Re: floyd]
#1062818
08/25/11 05:38 PM
08/25/11 05:38 PM
Posts: 4,115 MD
floyd
MD
I haven't seen any others that thin. I think the idea is you can use two wrenches (1" and 1/2") when tightening/loosening the fule lines. After looking at my carbs, it's unlikely that would work anyway. It's too tight a fit in there. I'm checking to see if this might work: http://cgi.ebay.com/ebaymotors/ws/eBayIS...AAQ:MOTORS:1123
[Re: floyd]
#1062819
08/25/11 05:44 PM
08/25/11 05:44 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
FWIW back when I ran a sixpack I would replace the inlet fittings for ones that had a second smaller set of wrench flats so taking the fuel lines apart was easier... Some of the older Holley fittings had the 1" hex and a 11/16 hex which worked great...
[Re: floyd]
#1062821
08/25/11 06:29 PM
08/25/11 06:29 PM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
This wrench is sold by a member of the board, looks like it would work fine .
[Re: hemi71x]
#1062826
08/26/11 03:49 PM
08/26/11 03:49 PM
Posts: 1,145 ontario calif
ns1aar
ontario calif
Took an old wrench and ground it down to fit
NS1AAR
[Re: ns1aar]
#1062827
08/26/11 04:27 PM
08/26/11 04:27 PM
Posts: 1,074 detroit, mi
POS Dakota
detroit, mi
Yeah, but that's the easy way.
[Re: POS Dakota]
#1062828
08/27/11 12:18 AM
08/27/11 12:18 AM
Posts: 20,865 A collage of whims
topside
A collage of whims
We make & sell a thin, heat-treated 1" wrench specifically for this application. Less expensive than anyone else's, too. $22.00 + $3.00 shipping. Got tired of trying to wrangle a wrench between my Holley & the firewall on my racecar and garfing up the fittings, bowls & firewall. You can PM me here, or email me directly at topside340@yahoo.com, or look me up on ebay as seller name "topside340", if you want one.
[Re: topside]
#1062829
08/27/11 01:13 PM
08/27/11 01:13 PM
Posts: 15,491 the boonies
aarcuda
the boonies
That's. Cool wrench. I changed over to the an lines. Pricey fix lol
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
