Budget 318 head options for my project truck? #1062789
08/25/11 11:14 AM
08/25/11 11:14 AM
Dearborn, Michigan
jstollfu Offline OP
jstollfu  Offline OP
Dearborn, Michigan
I’m looking for suggestions for budget 318 head options for my 76 Dodge D100 low rider project truck.
This entire project has been on an extreme budget so I’m not looking to spend a bunch on the heads.
What I have is a 76 D100 with a 318 2bl. It runs pretty decent showing 68,000 miles. I’m looking to upgrade with a few mild performance parts to make a little more power but still keep the truck very drivable. I have a 360 sitting on an engine stand that will get built up later on as $$ allows, so the upgrades to the 318 have to stay low budget. I have at this time already installed headers and dual exhaust (which made it run and sound a lot better). I’ve picked up a small RV cam, new lifters and new springs to match the cam. I have a used Edelbrock performer intake and a used Holly 650. If I was looking to swap the heads and not spend a bunch of $$ what should I be looking for? I know some of the 318’s had 1.88/1.60 valves and I’d like to increase the valve size yet keep a decent compression ratio with the stock 318 pistons. I don’t intend to get into the short block on the 318 except for the cam swap. If I go wrecking yard shopping what types of applications where those found in? Cop cars? Trucks? Should I be looking for a Magnum 318 with swirl ports? I admit I’m not very well versed in the newer small block stuff and interchange ability with the older small blocks. I want to end up with a compression ration around 9:1. So if I have to have the heads milled to obtain that, I might be able to spend the money to get that done. Or should I just have a quick valve job done on the stock 1976 318 heads back cut the valves, port match the intake and run it?
Any suggestions are appreciated. Thanks, Josh-
Re: Budget 318 head options for my project truck? [Re: jstollfu] #1062790
08/25/11 11:47 AM
08/25/11 11:47 AM
maybe some JY mag heads but reportedly alot of em are cracked but people have used them as is. You'd need a mag intake/pushrods. some 302's would bump the CR a bit & would bolt right on since their LA's
Re: Budget 318 head options for my project truck? [Re: RapidRobert] #1062791
08/25/11 12:04 PM
08/25/11 12:04 PM
Dearborn, Michigan
jstollfu Offline OP
jstollfu  Offline OP
Dearborn, Michigan
Please school me a little, what are 302's?
Thanks, Josh-
Re: Budget 318 head options for my project truck? [Re: jstollfu] #1062792
08/25/11 12:38 PM
08/25/11 12:38 PM
they're closed ch so it'd bump the CR up a bit which'd b good 4 you if you could find a set 4 cheap/ready 2 go as you wouldn't want to put alot into them.Prob some mag heads would b more practical but you need a mag manifold as I dont think you want to redrill the heads' intake holes at this point. Not sure on the 302 yrs avail but it'd b better to find a set of them (or mags) 4 sale ready to bolt on & a set of early 273 heads which are closed ch would b good & nobody wants them. do some searching & get a good bargain
Re: Budget 318 head options for my project truck? [Re: RapidRobert] #1062793
08/25/11 12:47 PM
08/25/11 12:47 PM
Dearborn, Michigan
jstollfu Offline OP
jstollfu  Offline OP
Dearborn, Michigan
Do the 302's have the 1.88/1.60 valves? I knew the 273 heads were a closed chamber, but don't they have the smaller 1.75/1.50 valves? I was looking to increase the flow a little. Does 302 refer to a cast number? I'm willing to invest a few hundred into a set of heads. Just not a grand. Josh-
Re: Budget 318 head options for my project truck? [Re: jstollfu] #1062794
08/25/11 12:52 PM
08/25/11 12:52 PM
iirc the 302 (yes the casting #) have 1.78's. the CR will benefit u more than the valve size plus do a bit of judicious porting esp the bowl right below the seat
Re: Budget 318 head options for my project truck? [Re: jstollfu] #1062795
08/25/11 12:56 PM
08/25/11 12:56 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
For a budget, and future use on a 360, I'd recommend Magnum heads. Yep, lots of JY ones are cracked, but they'll be cracked on wrecked vehicles, and they don't crack from sitting. They'll be fine. If you want to drop $700 now, get Enginequest or Hughes Iron Rams, they are new/improved non-cracking Magnums with better ports.
Search for Magnum builds and posts by Patrick and Scratchinfotraction. They always have good info.
Re: Budget 318 head options for my project truck? [Re: Fury Fan] #1062796
08/25/11 02:38 PM
08/25/11 02:38 PM
Dearborn, Michigan
jstollfu Offline OP
jstollfu  Offline OP
Dearborn, Michigan
Sounds like the 302's are what I want. What did they come on? I'll have them surfaced if need to increase the C/R.
I have a good set of early 360 heads that have been angled milled and have had stainless steel 2.02/1.60 valves installed. I'm just keeping those on the 360 until I get $$ ahead to build it up again. Long story but the 360 was in an 84 D150 that was in an accident and the truck was totaled. It ran 12.80's in the D150. But it needs to be completely gone through again. I just want to slighty build up the old 318 until funds allow me to do the 360 corretly.
Re: Budget 318 head options for my project truck? [Re: jstollfu] #1062797
08/25/11 06:18 PM
08/25/11 06:18 PM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
302 is the casting number. they have small valves and are about 62cc`s. most easily found on 80`s grand furys/diplomats/trucks and vans. easily ID`d by their heart shaped combustion chamber. if you go to the junk yard to pull them yourself take along a set of metric sockets to remove the exhaust manifold bolts. they get rusted so bad std. tools will not fit and they you are stuck not being able to remove the ex. manifold.
Re: Budget 318 head options for my project truck? [Re: 65rbdodge] #1062798
08/25/11 10:57 PM
08/25/11 10:57 PM
scratchnfotraction Online tonguue
scratchnfotraction  Online Tonguue
4-v 318 will have the 360 head with 1.88/1.60 valves and open chambers with low comp ratio.
comes stock with flat tappet cam ,but may be a roller cam block on mid to late pre-mag engines.
2-v 318 has the #302 casting heads with 1.78/1.50 vales closed chambers and will be on a 9.0 to 1 comp 318 starting in 85 with roller cams start in 85 in cars only.
2-v 318 trucks got a roller block/flat tappet cam with #302 heads in 85.
you can up the #302 valve size to 360 size of 1.88/1.60 and with some pocket porting to open the bowl,the small ports will keep volosity up and have more flow with the bigger valves.
360 heads flow more on top but lower comp ratio but with the right cam can be made to work on upper rpm
#302 head will up the comp ratio,make more torque on the lower rpm of your stock bottom end
if you went with complet newer engine you would be ahead by running a retro roller cam in the stock long block
I just picked up a 91' pre-mag roller cam TBI 318 with swirl port fast burn closed chamber 9.0 to 1 comp ratio for my 85 stepside engine swap.
i will be swaping in the lanati VooDoo roller cam and springs along with a LD4B intake(matches 318 head ports) with 600 cfm carb and headers
should be a peppy little 318 by monday
#302 heads 85 to 91
some later ones may have a diff casting # but as long as they are heart shaped combustion chambers its the same thing.
Re: Budget 318 head options for my project truck? [Re: scratchnfotraction] #1062799
08/26/11 12:11 AM
08/26/11 12:11 AM
Woodward, PA
75DART440 Offline
75DART440  Offline
Woodward, PA
Don't forget B-vans. Any 318 2 barrel from 86 thru 91 should have the 302s. I have managed to hoard 4 sets of these, and I don't think I spent more than a hundred bucks on any set.
As for magnum heads, these would require special lifters due to the way the rockers are oiled vs the way the LA rockers are oiled. With the 302s, it's just: 1)buy gaskets 2)install 3)smoke tires
Buy a Hybrid!! I need your gas!!! Currently spending $1,000 a month to feed the Hemis!! Looking for that elusive CHEAP 71-72 Plymouth B-body 2 door OR 71-72 Coronet 4 door!!!
Re: Budget 318 head options for my project truck? [Re: 75DART440] #1062800
08/26/11 08:53 AM
08/26/11 08:53 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
"special lifters" meaning any aftermarket lifter that also cross references to an AMC application, which is pretty much every aftermarket lifter.
going to 302 heads, they won't flow any better than your open chamber 318 heads. the 1/2 to 3/4 point increase in compression won't net much power improvement, maybe 2-3% max.
I'd go with junkyard magnum heads, and redrill them to LA intake angle. get junkyard 2.2L spring retainers, and then get hughes #1110 valve springs. a comp XE256 or a lunati voodoo 60401 would be a nice cam for your combo.
2017 Grand Cherokee Overland
Re: Budget 318 head options for my project truck? [Re: jstollfu] #1062801
08/26/11 09:25 AM
08/26/11 09:25 AM
Dearborn, Michigan
jstollfu Offline OP
jstollfu  Offline OP
Dearborn, Michigan
Thanks for the info. I'm going to check out some local pick-a-part wrecking yards. I'm sure I can find a set of 302's. What is going price for basically a "core" set of heads? I'd like to go to a 11/32 stem valve and increase intake and exhaust dia. But that starts Adding $$ up qucik witht he extra machine work. Kind of defeats the intent. But I'll port match, and blend the bowls. Maybe have them surfaced. Run the thinner head gasket? Should work better then the stock 76 318 heads. Josh-
Re: Budget 318 head options for my project truck? [Re: jstollfu] #1062802
08/26/11 01:19 PM
08/26/11 01:19 PM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
i can get a set at the upullit for about $60
Re: Budget 318 head options for my project truck? [Re: jstollfu] #1062803
08/26/11 01:53 PM
08/26/11 01:53 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
well, magnums are 1.92/1.625 with 5/16" valve stems already...I personally wouldn't sweat it if you did get a pair that was cracked (mine off a '94 5.2L weren't), as long as there are no water leaks when pressure tested
once you get into new (smaller stem) valves, and the corresponding new valve guides, machine work, and a new spring package for a hotter cam, you might as well get these: hughes LA intake "Iron Ram" enginequest heads
granted, 2 years ago, they were $150/pr cheaper....
depending on what they used for a spring package, these may not be a bad deal, either. just stay away from the really cheap "New" magnum heads on ebay, those are a chinese pro-comp head, very poor quality.
Re: Budget 318 head options for my project truck? [Re: patrick] #1062804
08/26/11 03:13 PM
08/26/11 03:13 PM
Dearborn, Michigan
jstollfu Offline OP
jstollfu  Offline OP
Dearborn, Michigan
Thanks, that gives me an idea what to spend. Not going the magnum route. I want to stay at maybe $300-400 in head work. With the headers, 276/286 .441 cam, new springs, increase in compression. performer intake and Holly 650. It will run decent enough to cruise around and with the 3.91 gears in the back it will be fun.
The 360 will get bored and new pistons a 290 cam of some sort and will replace the 318 in about a year.
If I really want to get crazy I have a 340 with Brodix BA-B1's that have been milled down to 48cc chambers. Fully ported by Koffels, Eagle rods, roller cam, 1050 dominator etc, etc. but's that's a whole different story.
Thanks for all the info guys... Josh-
