Alchohol Timing ??? #1062593
08/24/11 10:30 PM
08/24/11 10:30 PM
In the 8's
FY1TA Offline OP
FY1TA  Offline OP
In the 8's
I switched from 110 to Alky . Would there be any difference in what to set the timing at or plug gap ?
Re: Alchohol Timing ??? [Re: FY1TA] #1062594
08/24/11 10:36 PM
08/24/11 10:36 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
I use about .005 less gap and about 2*-3* less timing.I havent really noticed much difference though.
Re: Alchohol Timing ??? [Re: DavidDean] #1062595
08/25/11 12:30 AM
08/25/11 12:30 AM
Tennessee
steeldust Offline
steeldust  Offline
Tennessee
The plugs is the same gap but you can go colder on the plugs if you won`t and the timing is about the same my 572 run the best at 38 degree but at 35 degree about the same a lean out valve is a must to warm the car up. GOOD LUCK
Re: Alchohol Timing ??? [Re: steeldust] #1062596
08/25/11 01:24 AM
08/25/11 01:24 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
34 deg timing, keep the gap .035 or less. I lost some good power and tyook me forever to figure out it was the plug gap... They were .045+ slowed down a bunch...
850 HP engine with a toilet injection.
Re: Alchohol Timing ??? [Re: Bob_Coomer] #1062597
08/25/11 08:16 AM
08/25/11 08:16 AM
gregsdart Offline
gregsdart  Offline
15.1/1 compression, 440-1 heads, alky, .025 to .027 to .032 gaps tried, all work well. Timing 34 degrees, all timing marks dead on. NGK -9 plugs.
