Re: New 512 stroker build, ZERO power!
[Re: MR_P_BODY]
#1062480
08/31/11 07:34 PM
08/31/11 07:34 PM
Posts: 740 Anderson, IN
1969RR
Anderson, IN
I'm curious to what was making the little (we will call them ball bearing marks) in the heads and or cyl... you tried 2 ignition set ups didnt you... so your down to fuel... if it was bad fuel it would detonate and could leave marks... plus run BAD... how old was the fuel
Hello, After I removed the heads, I found it was not dimples as we thought. We were looking in the cyls with a bore scope. I think we were seeing reflections off of the gooy stuff on the piston tops. Looked like a mixture of oil / gas goo. Wiped right off, piston looked like new. I have the engine all apart, and see nothing! No marks anywhere indicating anything hitting. Yes, I tried 2 ignition systems, no difference. Initial start was with the fuel in my tank. The tank was almost empty, so I put in 10 gals of 93 octane before I started the engine. Later, I hooked a hose directly to a 5 gal can of 110...NO difference. UNLESS, I washed the cyls down right from the get-go and caused my problems. Still hunting. Waiting now for the tech from 440Source to call me back. Thanks, Jeff
[Re: 1969RR]
#1062481
08/31/11 07:56 PM
08/31/11 07:56 PM
Posts: 614 Michigan
Get-X
So are you somewhat carb savvy? I ask this because all along I kept thinking you had a stuck float or a dirty/worn or sticky needle & seat and wondered if you could tell the difference? I can't tell you how many times people I know who are very smart sometimes overlook the simplest things. Then when you mention the "grey goo of death" I really think you washed and wiped the rings.
'65 Belvedere '68 GTX '57 Dodge pickup
[Re: RalleyA12]
#1062483
08/31/11 10:23 PM
08/31/11 10:23 PM
1969RR
Anderson, IN
Could the rings be installed upside down causing a compression loss ?
Nope, checked that too...Thought that myself. Jeff
[Re: 1969RR]
#1062484
08/31/11 11:41 PM
08/31/11 11:41 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
[quote Waiting now for the tech from 440Source to call me back.
Sorry, I just had to....
Did the motor show any signs of excessive blowby?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: 1969RR]
#1062485
09/01/11 12:51 AM
09/01/11 12:51 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Hello all! I've So, I take it out for a test drive..NO power at all. I doubt if it would burn rubber! Seems like a slight miss out at light cruise. I have taken out plugs. Might be a bit rich, Looked in chamber with a Snap-On bore scope, adjusted rockers ICE-EOI method 3 times Jeff
After reading all of your posts! IMO This is a bogus type thread You state above, you doubt if it will burn the tires
The combo as listed should rock. I think your mocking Moparts.
[Re: Von]
#1062486
09/01/11 08:23 AM
09/01/11 08:23 AM
1969RR
Anderson, IN
Thurs morn......and, I'm still waiting! LOL.. Maybe they'll call today, ya think?? Yes, I did have some..I could feel slight "puff" out of the valve cover breather ports. Jeff
[Re: Sport440]
#1062487
09/01/11 08:26 AM
09/01/11 08:26 AM
1969RR
Anderson, IN
DO WHAT? Not mocking anything, just seeking advise! Jeff
[Re: 1969RR]
#1062488
09/01/11 09:45 AM
09/01/11 09:45 AM
Posts: 75,008 U.S.S.A.
JohnRR
U.S.S.A.
Well it was only 4am ish there , what are you expecting to get out of a conversation with them ??
[Re: 1969RR]
#1062489
09/01/11 10:04 AM
09/01/11 10:04 AM
Posts: 690 New Hampshire, USA
oldiron
New Hampshire, USA
Just a thought, blocked exhaust will cause the same problem. Old double wrapped pipes would sometimes buckle on the inside and not be visible on the outside - try running w/o exhaust if you had one on for your street test
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge New New Best: 10.56 @129 68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up https://www.youtube.com/watch?v=T4jDLKwd9Gs
[Re: RTSrunner]
#1062492
09/01/11 12:22 PM
09/01/11 12:22 PM
JohnRR
U.S.S.A.
Was a leak down and/or a compression test done before the engine was disassembled ?A leak down test would sure help with a direction to go,be it rings,valves or gasket issues.Leaking rings may not look bad to the eye.
he did a compression test , think it read 155psi ?
[Re: FastmOp]
#1062498
09/01/11 04:53 PM
09/01/11 04:53 PM
Posts: 2,141 junction city oregon
viperblue72
Looks to me like you just don't know what your doing. Either pay someone or sell it. Your over your head.
Fastmop! Is your name Dick?
