Page 6 of 10 1 2 4 5 6 7 8 9 10
Re: New 512 stroker build, ZERO power! [Re: Dodgeguy101] #1062440
08/26/11 01:07 PM
08/26/11 01:07 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Good thing you guys aren't doctors, the patient would be dead already.
good one
Re: New 512 stroker build, ZERO power! [Re: 1969RR] #1062441
08/26/11 01:50 PM
08/26/11 01:50 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
You still have to use the degree wheel properly zeroed. a solid lifter and your dial indicator to know where the cam is really fazed.
and those spark plugs are way too cold!
I tried another set, hotter, more of a race plug. Didn't help at all. Blacker than black after 20 mins of run time! For sure, not complete combustion. Jeff
You have C57YC plugs in now not much more race around that that these are for 13 to 14 to 1 compression.
I would try champions RC12YC get street plug.
I would borrow a know good carb.
I would re check cam degree "with a solid lifter!!!!"
Then I would check the spark
Then I would start backing the pre load off 1 turn at a time till it starts to tick on all cylinders. if it takes more than 1.5 turns probably your problem.
Just My
Re: New 512 stroker build, ZERO power! [Re: Dodgem] #1062442
08/26/11 01:58 PM
08/26/11 01:58 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Just curious, how much fuel pressure do you have? Todd
Re: New 512 stroker build, ZERO power! [Re: sasquatch] #1062443
08/26/11 02:22 PM
08/26/11 02:22 PM
Anderson, IN
1969RR Offline OP
1969RR  Offline OP
Anderson, IN
Dodgem & Todd, I did switch to Champion C59CX plug. This is the same plug my machinist runs in his street stocker 11:1 compression. He was the one that suggested these. They fuel fouled just like all the others (NGK type). I'm running a stock carter 6pak style pump. So, I'd say 5-6PSI on pressure. I'm going to go get some 110 octane and run directly out of my gas can, by-pass the tank altogether. I'll get back! Take care!! Jeff
Re: New 512 stroker build, ZERO power! [Re: 1969RR] #1062444
08/26/11 05:00 PM
08/26/11 05:00 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Thinking back to when my cam bolt cam loose and it was bending all the valves it was way down on power and black the spark plugs too??
just a thought.
You should not need any more than 93 octane but cats like budgies too expensive but don't hurt the cat! :-)
Your sure you don't need to try another carb??
And you are sure you don't have the pre load too tight???
Re: New 512 stroker build, ZERO power! [Re: Dodgeguy101] #1062445
08/26/11 05:30 PM
08/26/11 05:30 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Diet Pepsi RIGHT THROUGH THE NOSE!! That was FUNNY ! ! !
Back on point: 110 octane isn't going to solve your problem. No matter what octane, the motor appears to be dead rich.
But since the front of the motor is apart, PLEASE re-degree the cam with a SOLID lifter using the #1 INTAKE lifter bore. Run it...
"The plugs are the window to the motor's soul". It either has WAY too much fuel, or not enough spark. Since you've had the same results with two diff ignition boxes...try a different dizzy...or go over yours with a fine tooth comb to ensure all is well.
But the rattling noise you hear...?? That is a brain bender.
HURRY UP, will ya! I like a good mystery, but I can't wait to see it solved!
"Good thing you guys aren't doctors"...I'm STILL chuckling over that one...
Re: New 512 stroker build, ZERO power! [Re: cudadoug] #1062446
08/26/11 05:42 PM
08/26/11 05:42 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
Is it possible Cam went flat on break in?
Re: New 512 stroker build, ZERO power! [Re: viperblue72] #1062447
08/26/11 05:51 PM
08/26/11 05:51 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
MAYbee and a good idea .....time to remove the oil-filter and cut it apart.
Re: New 512 stroker build, ZERO power! [Re: dOrk !] #1062448
08/26/11 10:42 PM
08/26/11 10:42 PM
Anderson, IN
1969RR Offline OP
1969RR  Offline OP
Anderson, IN
Hey guys. Seems like she's commin' out....again! Machine shop / engine builder friend came by again tonight. Eliminated fuel question. I ran a line straight from a 5 gal can of 110 octane. Pulled all plugs again. Loosened all rockers 1 full turn. Looked in chambers with bore scope thru plug holes. Doesn't look good. Looks like something was in there. Small indentations, almost like grains of sand or very small ball bearings. All we could see was the marks on the pistons, never found anything difinitive. Put plugs back in. Crank, crank, crank....forever to get to start. Never has fired right up like it should from the start. We think whatever is/was in there is causing problems. So, I started taking it out. I can't tell you how depressed and frustrated I am with this! Oh well! Practice makes perfect..and I'm getting good. I'll let ya know what I find when she comes apart. Thanks again guys, you are the greatest! Take care, Jeff
Re: New 512 stroker build, ZERO power! [Re: 1969RR] #1062449
08/26/11 10:45 PM
08/26/11 10:45 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Guess you found your rattling sound... You'll bounce back keep your head up
Mopar Performance
Re: New 512 stroker build, ZERO power! [Re: 1969RR] #1062450
08/26/11 10:53 PM
08/26/11 10:53 PM
MR_P_BODY Offline
MR_P_BODY  Offline
BUMMER
Re: New 512 stroker build, ZERO power! [Re: moparniac] #1062451
08/26/11 11:00 PM
08/26/11 11:00 PM
Anderson, IN
1969RR Offline OP
1969RR  Offline OP
Anderson, IN
My machinist said the same thing! LOL Thanks! Jeff
Re: New 512 stroker build, ZERO power! [Re: 1969RR] #1062452
08/26/11 11:06 PM
08/26/11 11:06 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Let us know what you find. When you get it back together,bring it up and we can break it in on the dyno and know all is well in the engine before you bolt it back in.
With the dyno having a known good ignition and fuel system you at least are ahead of the game,then if all is not right in the car you know it is one of those systems.
Keith
Re: New 512 stroker build, ZERO power! [Re: Dunnuck Racing] #1062453
08/26/11 11:08 PM
08/26/11 11:08 PM
Anderson, IN
1969RR Offline OP
1969RR  Offline OP
Anderson, IN
Thank you Keith! I will keep in touch! Jeff
Re: New 512 stroker build, ZERO power! [Re: 1969RR] #1062454
08/26/11 11:57 PM
08/26/11 11:57 PM
NC
440Jim Offline
440Jim  Offline
NC
Have the valves checked. They could be slightly bent from the debris, so they don't seal properly.
Re: New 512 stroker build, ZERO power! [Re: 440Jim] #1062455
08/29/11 12:26 AM
08/29/11 12:26 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
Re: New 512 stroker build, ZERO power! [Re: 70blackfish] #1062456
08/29/11 05:42 AM
08/29/11 05:42 AM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
I know the damage has been done... but I waited and waited and no one mentioned putting an offset key in the crankshaft throws the timing marks off on the balancer. Add in another offset camshaft sprocket key and no telling where the timing will come out if you don't find the engine's true TDC with a degree wheel and dial inda(or pos. stop)...
Could be where the damage came from if that was overlooked.
I feel better..
Re: New 512 stroker build, ZERO power! [Re: 52savoy] #1062457
08/30/11 08:25 PM
08/30/11 08:25 PM
Anderson, IN
1969RR Offline OP
1969RR  Offline OP
Anderson, IN
Hey everyone! Thought I'd give somewhat of an update. I pulled the engine again. Boy, I'm getting good at that! Anyway, when I pulled heads, I noticed an excessive amount of oil/fuel "gummy" stuff on the piston tops and the combustion chambers. Nothing foreign had got in there like we thought tho. No physical damage at all. Guess that's good. Got everything off engine except the rotating assy. When I spin the engine with a ratchet, I hear the "thunk" sound that is what I think I heard when it was running. More than one "thunk", multiple...If I put my hand on any piston and rotate the engine, I can feel the "thunk". I can rock the piston as it goes up and down. Pulled one (for now) measure it and it is 4.355" This is a 440 + .040, so .005 piston to wall. Too much?? Is the piston supposed to rock like that?? Remember, I'm using the 440Source 512 kit. Icon pistons. Also, seems like a lot of ring grind in oil. Oil is very "grey" in color and gritty. Bearing look like new. The rest is gonna come apart tomorrow. I just wish I could see something definitive! Still can't explain why no power either. Mystery! Thanks everyone! Jeff
Re: New 512 stroker build, ZERO power! [Re: 1969RR] #1062458
08/30/11 08:59 PM
08/30/11 08:59 PM
WA
JD Dart Offline
JD Dart  Offline
WA
Silly question but how far do the pistons come up measured from the deck mine are .010 down at TDC
best so far 8.53 @ 158.59 MPH 60'1.240
Re: New 512 stroker build, ZERO power! [Re: 1969RR] #1062459
08/30/11 09:20 PM
08/30/11 09:20 PM
Mesa, AZ
cagebob1 Offline
cagebob1  Offline
Mesa, AZ
any chance that you actually have a solid lifter camshaft? Many years ago I put a motor together that ran/started just as you described.. turns out that it had a solid lifter cam instead of hydraulic. without the lash, the compression/power was WAY down. simply adjust the valves like it's go solid lifters and give it a quick try.
just my
