Page 4 of 10 1 2 3 4 5 6 9 10
Re: New 512 stroker build, ZERO power! [Re: Jeepmon] #1062400
08/25/11 01:52 PM
08/25/11 01:52 PM
San Angelo, Texas, U.S.A.
1968RR Offline
1968RR  Offline
This sounds familiar...I had a similar problem a couple of years ago and it turned out that my timing chain had jumped during break-in. If you start losing teeth on your ring gear, this is your problem.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
Re: New 512 stroker build, ZERO power! [Re: 1968RR] #1062401
08/25/11 01:58 PM
08/25/11 01:58 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Double check the dial on your digital box and then make sure it's set to not pull out the 20* and see how it starts for ya! That may atleast help that issue.
Mopar Performance
Re: New 512 stroker build, ZERO power! [Re: moparniac] #1062402
08/25/11 02:02 PM
08/25/11 02:02 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
any up dates?
Re: New 512 stroker build, ZERO power! [Re: 70blackfish] #1062403
08/25/11 02:18 PM
08/25/11 02:18 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
any up dates?
I know, I'm hooked on this one. I need to know what the deal was or it's going to bother me.
Re: New 512 stroker build, ZERO power! [Re: Dunnuck Racing] #1062404
08/25/11 02:25 PM
08/25/11 02:25 PM
Anderson, IN
1969RR Offline OP
1969RR  Offline OP
Anderson, IN
Hey everyone! Guy's I really appreciate all the help on this one. I have double/triple check'd TDC, where the rotor is at #1, plug wires are on the correct plugs, etc. I just did a compression test. Not good IMO. All plugs out, carb WOT, 150-160psi...I would think should be over 200 with my set-up. I'm thinking timing gears are not correct. I used the double roller timing set-up with the multiple crank way. I thought I installed it at 2deg advanced, but now, I'm almost positive I goofed up somewhere.
I just looked at the MSD wires again. At the plug at the MSD box, the tach wire is definitely grey or tan. I'm color blind on light colors.
Keith, you are a gentleman and a scholar! I really appreciate the offer and would make it worth your while! If I can't figure this out by checking the timing / degreeing, I'll take you up on the offer!
Again, thanks a bunch!! Jeff
Re: New 512 stroker build, ZERO power! [Re: 1969RR] #1062405
08/25/11 02:51 PM
08/25/11 02:51 PM
ill
dennismopar73 Offline
ill
you always hope for the simple,,!
work backwards, then find the solution,
hope all goes great, sound like it ought to be great motor for you
Re: New 512 stroker build, ZERO power! [Re: 1969RR] #1062406
08/25/11 02:53 PM
08/25/11 02:53 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
If you want,let me know when you get everything apart to check the cam timing and I will come down and help you with it if you are unsure.
I just want to see you get it running well.
Something else I thought of,do you know you have good fuel in it? I had mine start running similar to yours one year after running all year and then got a bad batch of fuel. I replaced eveything ignition wise at my team finals trying to find the problem,only to have my other car do the same thing when I got home and dumped my remaining fuel in it.
Sometimes it is a totally different problem than you might think.
Keith
Re: New 512 stroker build, ZERO power! [Re: MRMOPAR622] #1062407
08/25/11 03:16 PM
08/25/11 03:16 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
? maybe....
Solid Core spark plug wires cannot be used with an MSD Ignition.
Mopar Performance
Re: New 512 stroker build, ZERO power! [Re: moparniac] #1062408
08/25/11 03:19 PM
08/25/11 03:19 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Mopar Performance
Re: New 512 stroker build, ZERO power! [Re: PHJ426] #1062409
08/25/11 03:32 PM
08/25/11 03:32 PM
Mt.Vernon IL
Twin Turbo Mower Offline
Mt.Vernon IL
What carb are you using? Maybe try a different one?
Re: New 512 stroker build, ZERO power! [Re: moparniac] #1062410
08/25/11 03:35 PM
08/25/11 03:35 PM
Anderson, IN
1969RR Offline OP
1969RR  Offline OP
Anderson, IN
Sledgehammer, Mine is totally different. Mine is the MSD 6425 6AL, NO spark retard. It has 2 looped wire to cut if using a 4 or 6 cyl engine. Page 2 has instructions for tach. Quote:" the MSD Ignition features a gray tach output wire that provides a trigger signal for tachometers."
I had FireCore make the plug wires this year at the Nats. I told them I was using an MSD system. I hope the wires are the correct ones and not solid core. Take care, Jeff
Re: New 512 stroker build, ZERO power! [Re: Dunnuck Racing] #1062411
08/25/11 03:36 PM
08/25/11 03:36 PM
Southington, Ohio
dm69charger Offline
dm69charger  Offline
Southington, Ohio
I had the same problem.....bad gas! I replaced everything and was extremely frustrated until I found the problem. Initially I ruled out it being a gas problem because I had just put fresh gas in it. I drained the bad gas out of it, put fresh gas (from another gas station) back in it and the car has been running great ever since.
Re: New 512 stroker build, ZERO power! [Re: 1_WILD_RT] #1062412
08/25/11 04:12 PM
08/25/11 04:12 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i helped a friend with some new 6-pak carbs once. while doing an inspection of the carbs i found the vacuum passage to the pods on both end carbs blocked with brass plugs. this was a factory booboo. disconnect the end carbs from the linkage and pull some vacuum on them to see if they're working.
Re: New 512 stroker build, ZERO power! [Re: 1969RR] #1062413
08/25/11 05:30 PM
08/25/11 05:30 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
First you compression is about 10.25 so 150 to 160 is not that bad with a 246 deg cam.
did you check you cam degree again after picking the +2 deg keyway?
always check check recheck
next 57s are way way too cold for that engine go with 61's or even 63's
just go to your local parts store and grab a set of RC12YC and put in to try!
you are sure your firing order is correct?? seen a guy swap 6 and 8 and is power was down 40% and they are so far appart in the firing order not mush ill effects just two cold holes! and of course 5 and 7 are easy to mix up! :-)
On second thought you should be around 180 so maybe you cam is installed retarded??
Re: New 512 stroker build, ZERO power! [Re: Dodgem] #1062414
08/25/11 07:25 PM
08/25/11 07:25 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
A temp. gun will tell you if you have a weak cylinder.
If you have tried everything else and nothing has worked,it may be time to try and set your dist drive gear like it calls for. I had the same problem and that was the fix for me. Some times its the simple things that get you. I know everyone thinks I wrong but is it not a least worth a try?
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: New 512 stroker build, ZERO power! [Re: MRMOPAR622] #1062415
08/25/11 08:57 PM
08/25/11 08:57 PM
Anderson, IN
1969RR Offline OP
1969RR  Offline OP
Anderson, IN
Hello Everyone! Pulled front of engine apart this afternoon. I was hoping to find I had gears off. Well, according to my machine shop / engine builder, it is the way it should. I've attached a pix of the gears. We called Comp. The cam is a custom grind. They said on 7 1/2 CL. I kept comming up with about 8 1/2 so I advanced it 2 deg. You can see this on the gears. Now I'm kind of back to square one! We are gonna double ck this again tomorrow. I did double ck at TDC and I'm pointing at #1 on the dist. Firing order is correct. Checked 3 times with another set of eyes! I just can't see it being ignition related, because it ran the same with the Mopar ignition in it. Just very lazy, no power to get out of it's own way. Anyone ever heard of a cam doing this? Crank key wrong? I'm lost (again)! Take care, Jeff
Re: New 512 stroker build, ZERO power! [Re: 1969RR] #1062416
08/25/11 09:06 PM
08/25/11 09:06 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
Not sure who said it, too lazy to look, but now that you checked the cam, I would check lifter preload, valve adjustment. I would think even if only one carb was working it would still run okay. Did you check the gas like was suggested? I'm waiting to see what you find, interesting problem, hope I don't have the same one shortly.
Re: New 512 stroker build, ZERO power! [Re: moparniac] #1062417
08/25/11 09:06 PM
08/25/11 09:06 PM
NC
440Jim Offline
440Jim  Offline
NC
I once accidently put my MSD ignition on 6 cyl and I didn't notice the problem until I staged the car and hit the throttle. Way down on power and didn't sound/feel right, aborted run. i couldn't believe it wasn't more noticable.
So triple check the wires cut to make sure you are set for 8 cyl.
I have also seen cams ground way off, maybe 8 degrees as I recall. This was using the same crank, timing set, and block setup that I checked 5 other cams on. So it was the cam, the degree wheel didn't lie.
And if the polarity of the MSD connection to the distributer pickup is wrong, it will run like crap also. I have even seen the wire color code wrong. Swaping polarity did the trick.
Re: New 512 stroker build, ZERO power! [Re: 1969RR] #1062418
08/25/11 09:10 PM
08/25/11 09:10 PM
Texas, USA
ChrgrCuda Offline
ChrgrCuda  Offline
Texas, USA
Really stupid questio, but is it possible the plugs could have become gas fouled upon your initial break-in? I had a crate motor that behaved exactly this way, finding out later that I had gas fouled the plugs on a fresh small block crate motor. Just a thought.
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
Re: New 512 stroker build, ZERO power! [Re: 1969RR] #1062419
08/25/11 09:22 PM
08/25/11 09:22 PM
mi
RATPATROL Offline
RATPATROL  Offline
mi
try swapping dist. pick-up wires, seen this before
