Page 51 of 55 1 2 49 50 51 52 53 54 55
Re: I'm back with a new Mopar project! [Re: DusterDave] #1062033
02/10/15 02:07 AM
02/10/15 02:07 AM
Tampa
DusterDave Offline OP
Tampa
I've suffered with those crappy auto parts store brake flaring tools long enough. I bought an Eastwood Pro Flaring tool. This tool looks like an absolute joy to use! I can't wait until it gets here!
https://www.youtube.com/watch?v=8xGjYfl9bP0
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: I'm back with a new Mopar project! [Re: DusterDave] #1062034
02/11/15 01:18 AM
02/11/15 01:18 AM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
Just wanted to be post 1001
Re: I'm back with a new Mopar project! [Re: Al_Alguire] #1062035
02/11/15 01:32 AM
02/11/15 01:32 AM
Tampa
Tampa
Dang it Al, you treed me!!! Congrats, and thanks for stopping by my virtual garage!
Re: I'm back with a new Mopar project! [Re: DusterDave] #1062036
02/11/15 02:22 PM
02/11/15 02:22 PM
Las Vegas
Las Vegas
Dave I have followed along with the build. First and as usual it looks killer. Cannto wait to see the final product in all her glory!
Re: I'm back with a new Mopar project! [Re: Al_Alguire] #1062037
02/14/15 04:09 PM
02/14/15 04:09 PM
Tampa
Tampa
Thanks a lot, Al!
Re: I'm back with a new Mopar project! [Re: DusterDave] #1062038
02/14/15 04:09 PM
02/14/15 04:09 PM
Tampa
Tampa
I finished up the last bit of brake lines this morning, namely, making the two lines connecting to the master, adding the hydraulic brake switch to the front line, and adding the proportioning valve to the rear line.
I have to say, I no longer have to hope and pray when flaring brake lines anymore. This Eastwood Flaring tool is the BOMB-DIGGITY!! It's actually fun to make PERFECT double flares, and so quick and easy, too!! My only regret is that I wish I had bought it sooner.
Re: I'm back with a new Mopar project! [Re: DusterDave] #1062039
02/15/15 02:45 PM
02/15/15 02:45 PM
Tampa
Tampa
This morning, I set the pinion angle, and tack welded the perches in place. I was shooting for 2 degrees negative pinion angle, but 2.1 degrees is close enough.
After lunch, I'll tack weld the lower shock mounts to the axle housing, and then I can get it out from under the Jeep and prep it for paint. The plan is to spray one coat of my favorite heavy duty epoxy primer, Dupont Corlar 2.1 ST, and one or two coats of Dupont Imron satin black.
Re: I'm back with a new Mopar project! [Re: DusterDave] #1062040
02/15/15 11:37 PM
02/15/15 11:37 PM
Tampa
Tampa
To aid in getting the 14 bolt out, I fabbed up a temporary dolly, so I could maneuver it around, and to facilitate painting of the housing. Since I can't move the Jeep, I'm going to have to spray paint it outside.
Re: I'm back with a new Mopar project! [Re: DusterDave] #1062041
02/15/15 11:54 PM
02/15/15 11:54 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Imagine that a simple pinion angle without a political debate. Looking real nice Dave. With the pinion nose up so much will there be a need to adjust the oil level? I would imagine its pretty much up to the ring gear to toss it to the front. So the same fill just a different check point?
Re: I'm back with a new Mopar project! [Re: NITROUSN] #1062042
02/16/15 12:05 AM
02/16/15 12:05 AM
Tampa
Tampa
Truthfully, I don't know the answer to your question. I'll have to look into it.
Re: I'm back with a new Mopar project! [Re: DusterDave] #1062043
02/16/15 12:11 AM
02/16/15 12:11 AM
N
NITROUSN Offline
NITROUSN  Offline
N
I just noticed the fill is on the side of the case. I was thinking rear cover. So fill now to plug hole would raise it higher that if in stock pinion angle. If in fact the ring will supply oil to the front running it a little lower at the hole should work.
Re: I'm back with a new Mopar project! [Re: NITROUSN] #1062044
02/16/15 03:10 PM
02/16/15 03:10 PM
Tampa
Tampa
The final bullet list is getting short!
1. REAR AXLE:
a: Prime and paint it
b: Install it
2. Fill & bleed power steering/hydroboost system
3. Bench bleed the master cylinder, and bleed the brake lines
Re: I'm back with a new Mopar project! [Re: DusterDave] #1062045
02/18/15 10:26 PM
02/18/15 10:26 PM
Tampa
Tampa
Last night, the 14 bolt received one coat of Dupont Corlar 2.1 epoxy primer, and one coat of Dupont Imron 3.5 Satin Black.
Re: I'm back with a new Mopar project! [Re: DusterDave] #1062046
02/22/15 11:06 PM
02/22/15 11:06 PM
Tampa
Tampa
Today, I bench bled the master cylinder, and bled the braking system. That leaves just one last item to address, which is filling/bleeding the power steering/hydroboost system. Barring any unforeseen disasters, I will be taking this Jeep for a little test spin around the block next weekend!!!
Pic of the 14 bolt installed.
Re: I'm back with a new Mopar project! [Re: DusterDave] #1062047
02/24/15 04:55 PM
02/24/15 04:55 PM
Tampa
Tampa
So, here's where I'm at. Tonight, I'm going to cut 'n buff the doors, install them onto the Jeep, and install the door mirrors. Saturday, I'm going to fill and bleed the power steering/hydroboost system. After that, I will attempt a quick spin around the block.
Re: I'm back with a new Mopar project! [Re: DusterDave] #1062048
02/26/15 12:37 AM
02/26/15 12:37 AM
Lehigh Acres, Florida
rickstershemi Offline
Hope All Goes as Planned Dave
Rickster
Re: I'm back with a new Mopar project! [Re: rickstershemi] #1062049
02/26/15 11:54 AM
02/26/15 11:54 AM
Tampa
Tampa
Thanks, Rick! I have my GoPro mounted to the rollcage, so I'll post a video of that short first test drive.
Re: I'm back with a new Mopar project! [Re: DusterDave] #1062050
02/28/15 04:34 PM
02/28/15 04:34 PM
Southern by Choice
Shoozy Offline
I have a foot fetish
Shoozy  Offline
Southern by Choice
It's Saturday.
Old, tired, and sometimes broke down. Me, not my car...
Re: I'm back with a new Mopar project! [Re: Shoozy] #1062051
02/28/15 05:39 PM
02/28/15 05:39 PM
Tampa
Tampa
It's Saturday.
It's also pouring outside.
I really wanted to make the test drive on a dry day, so I could see if I'm trailing any fluids, plus I want to have the hood off, so we can see if and when the cooling fan kicks on automatically, or if anything is smoking in the engine compartment, we can spot it immediately.
Re: I'm back with a new Mopar project! [Re: DusterDave] #1062052
02/28/15 07:49 PM
02/28/15 07:49 PM
It's Saturday.
Remember People .... It's a Mall Crawler .... Getting it wet or dirty is not in the plan.....J/K
Rickster
