Re: I'm back with a new Mopar project!
[Re: rickstershemi]
#1061926
10/20/14 12:08 AM
10/20/14 12:08 AM
Posts: 1,845 Tampa
DusterDave
Tampa
I'm hoping to have it ready to drive by late December. My birthday is the day after Christmas, so that would be a nice present to myself.
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: DusterDave]
#1061927
10/22/14 12:53 AM
10/22/14 12:53 AM
Posts: 1,845 Tampa
DusterDave
Tampa
I got the starter relay mounted in an out of the way spot, close to the starter, yet accessible. It's ugly, so I didn't want it in plain sight. It's pretty much wired up, except for the main positive battery cable and a couple hex nuts. In order to cut the positive battery cable to the proper length, I'll need to know which side the positive post is on, which means I'll need to buy the battery. The winch is wired up, and I ran the main alternator feed wire. I purchased a voltage regulator kit, complete with harness. Hopefully it will arrive by Friday or Saturday, so I can get that bit squared away. I know this doesn't seem like much, but since I'm not electrically inclined, each connected wire and each installed component is a little victory. The Autometer 3-3/8" GPS speedo came in today. It has a lot of neat features. For instance, if I ever get stuck out in the middle of Moab, it can tell me what my coordinates are, and my heading. I can relay that information with my CB to a search party, and when they find me, they can load up my bones in a box and ship me home.
[Re: DusterDave]
#1061930
10/26/14 09:55 AM
10/26/14 09:55 AM
Posts: 1,845 Tampa
DusterDave
Tampa
Making progress on the wiring. The voltage regulator is installed and wired up, and the alternator is wired up, but I decided to increase the output cable size from 8 AWG that came with the kit to 6 AWG fine strand cable. I have a 120 amp alternator, and 8 gauge wasn't going to cut it. I ordered the 6 gauge cable and lugs online, and they should get here by midweek. I added Weatherpack connectors to the stop-turn-tail lights, the reverse lights, and the front side markers. The headlight switch is wired up. As I was routing the headlight wires to the front yesterday, I thought about using the two wires (hi-beam and low-beam) as activation wires for headlight relays. So, this morning I did some searching online, and found this really well built headlight relay kit. http://www.ceautoelectricsupply.com/h4headlightrelaykits.htmlIt will allow full battery voltage to be sent directly to the headlights, resulting in maximum brightness. Uses nice quality Hella waterproof relays. While its not cheap, I think its a good investment, and I don't mind paying a little more for safety related stuff. While I'm at it, I'm also going to upgrade to H4 headlights.
[Re: Quicktree]
#1061932
10/28/14 01:30 PM
10/28/14 01:30 PM
Posts: 1,845 Tampa
DusterDave
Tampa
Actually, I don't have a locking device for my spare tire, yet. I'll need to look into that. Yes, I'm still in Tampa. If you're ever in the Tampa area, you're welcome to swing on by JeeperDave Trailsports, Inc. (aka, my two car garage. )
