Page 39 of 55 1 2 37 38 39 40 41 54 55
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061793
05/10/14 04:47 PM
05/10/14 04:47 PM
Tampa
DusterDave Offline OP
Tampa
I test fitted the new Bestop soft top today.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061794
05/10/14 04:54 PM
05/10/14 04:54 PM
Tampa
Tampa
I got the 1 ton steering welded up. I'm still deciding whether to paint the bars or get them powder coated that speckled silver/black that you see on a race car chassis.
As a side note, I'm going to place the order for both driveshafts on Monday. Carolina Driveline will get the call to build them.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061795
05/10/14 08:52 PM
05/10/14 08:52 PM
Tampa
Tampa
After I test fitted the soft top, I wet sanded and buffed out the hood, and added the name of the Jeep.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061796
05/10/14 10:33 PM
05/10/14 10:33 PM
Tampa
Tampa
Other side. I wasn't sure that matte black was going to look good, but I like the contrast between the glossy red and the matte black.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061797
05/11/14 08:05 PM
05/11/14 08:05 PM
Tampa
Tampa
Half doors are painted. So, that's it for the smaller body parts. I hope to lift the tub off the frame next Saturday, and begin stripping it down to bare metal, and get going on the body work. My plan is to paint the tub on Memorial Day weekend, or at worst, the weekend after.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061798
05/15/14 02:27 PM
05/15/14 02:27 PM
Renton Washington
Triple Threat Offline
Renton Washington
Looking great Dave!
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: MY JEEP BUILD THREAD [Re: Triple Threat] #1061799
05/18/14 12:53 AM
05/18/14 12:53 AM
Tampa
Tampa
Looking great Dave!
Thanks, Dustin!
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061800
05/18/14 02:32 PM
05/18/14 02:32 PM
Tampa
Tampa
Houston....we have separation.
In addition to the body work, paint, and Monstalining the interior, there is work to do on the chassis as well.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061801
05/18/14 09:47 PM
05/18/14 09:47 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
its neked !!!
I am truckless..
Re: MY JEEP BUILD THREAD [Re: 340SHORTY] #1061802
05/18/14 11:45 PM
05/18/14 11:45 PM
Tampa
Tampa
its neked !!!
While she was "neked", I gave her the shaft, first from the front,and then from the rear.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061803
05/24/14 06:53 PM
05/24/14 06:53 PM
Tampa
Tampa
I completed half of the paint stripping work on the tub today. I used several different methods: chemical paint stripper to get most of it off, and a DA sander and a wire wheel to get the rest off. I'll finish stripping the other half tomorrow, and then it'll be ready for epoxy and high build prime coats on Monday.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061804
05/25/14 07:29 PM
05/25/14 07:29 PM
Tampa
Tampa
The tub is now completely stripped of all of that crappy orange paint!!
Tomorrow, we prime.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061805
05/26/14 01:22 AM
05/26/14 01:22 AM
Tampa
Tampa
Made a small amount of progress on the exhaust system this evening.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061806
05/26/14 01:29 AM
05/26/14 01:29 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
Hmmmmmmmmmn, that's interesting. Do I spy a trans cooler right above the skid plate? Keep on chugging along. I love your build. I hope I can get to my Dart soon.
Re: MY JEEP BUILD THREAD [Re: MuuMuu101] #1061807
05/26/14 02:28 PM
05/26/14 02:28 PM
Tampa
Tampa
Yep, that's the trans cooler. The skidplate has a large hole in that spot, so the trans cooler fan (puller) will be able to draw plenty of air.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061808
06/01/14 01:58 PM
06/01/14 01:58 PM
Tampa
Tampa
I admit, this isn't much to look at, but in the interest of chronicling all of the steps of my build, I'm currently in the process of doing the body work on the tub.
In an effort to give the sheet metal a smoother, continuous look, I filled in all of the body seams with All Metal.
I welded shut and smoothed over all un-needed holes in the firewall. I think it was about 25 holes in all.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061809
06/01/14 02:57 PM
06/01/14 02:57 PM
Tampa
Tampa
Building the tailpipes was a lot easier than I had imagined. A couple of 45º elbows and a section of straight pipe with a 25º baloney cut, some welding, and done! It's about time something was easy to do on this rig!! I plan on sending out the head pipes and tailpipes to be ceramic coated the same gray color as the headers.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061810
06/03/14 10:04 PM
06/03/14 10:04 PM
Tampa
Tampa
Wow, its a good thing I checked the blower motor to firewall fitment! Many months ago, I bought a new blower motor for the heater system. I recently read somewhere that the replacement motors are larger than the original motors. So tonight, I looked through my parts storage room, and found the new motor. I put it up to the hole in the firewall, and sure enough, its way too big. So, I grabbed the tin snips and increased the hole diameter by about a half inch. The adjacent smaller hole for the electrical connector had to be trimmed larger as well.
I'm just glad I discovered this BEFORE the firewall was painted! I'll make a sealing gasket out of closed cell foam.
BTW, the tub is scheduled to be painted on June 14th.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061811
06/03/14 10:47 PM
06/03/14 10:47 PM
Lehigh Acres, Florida
rickstershemi Offline
Good catch
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061812
06/03/14 10:49 PM
06/03/14 10:49 PM
Southern by Choice
Shoozy Online tonguue
I have a foot fetish
Shoozy  Online Tonguue
Southern by Choice
Mundane body work by some might not be much to look at but your creations need to be viewed at every stage to appreciate just how much work is involved in perfection. Carry on.
Old, tired, and sometimes broke down. Me, not my car...
