Re: MY JEEP BUILD THREAD
[Re: DusterDave]
#1061603
04/25/13 11:32 PM
04/25/13 11:32 PM
Posts: 1,845 Tampa
DusterDave
Tampa
I had to cut some access holes in the tub, in order to add some reinforcement behind the hinges. Instead of just using flat plate, I decided to use two pieces of 2" x 2" steel angle, cut 5-1/2" long. In addition to the hinge screws going through one side of the angle, when the tub comes off for body work and painting, I will drill holes and add bolts at the bottom, which will add more strength and support for the hinges. I'll make some sheet metal plates to cover the access openings. Access holes. Steel angle pieces for hinge reinforcement.
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: DusterDave]
#1061607
04/26/13 08:30 PM
04/26/13 08:30 PM
Posts: 1,586 Tampa, FL
tpabayflyer
Tampa, FL
Nice work Bud!! Are going with dual exhaust or a big single?
71 Challenger 528 Hemi project 09 Gr Cherokee 5.7 hemi in da house!!
[Re: DusterDave]
#1061609
04/27/13 05:44 PM
04/27/13 05:44 PM
tpabayflyer
Tampa, FL
Sounds good Mon!!!!! Pun intended! TBF
