Page 29 of 55 1 2 27 28 29 30 31 54 55
Re: MY JEEP BUILD THREAD [Re: Bad340fish] #1061593
03/21/13 10:26 PM
03/21/13 10:26 PM
Tampa
DusterDave Offline OP
Tampa
Tire mounting plate is on.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061594
03/21/13 11:00 PM
03/21/13 11:00 PM
Lehigh Acres, Florida
rickstershemi Offline
Nice Work....Looks Awesome !!!!!
Rickster
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061595
03/22/13 08:30 PM
03/22/13 08:30 PM
Southern by Choice
Shoozy Offline
I have a foot fetish
Shoozy  Offline
Southern by Choice
Old, tired, and sometimes broke down. Me, not my car...
Re: MY JEEP BUILD THREAD [Re: Shoozy] #1061596
03/22/13 10:17 PM
03/22/13 10:17 PM
Tampa
Tampa
Thanks, guys!
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061597
03/24/13 06:31 PM
03/24/13 06:31 PM
Tampa
Tampa
I added the D-ring recovery mounts. These 1" thick mounts go all the way through the bumper, and are welded at the front and back, for maximum strength. That's it for the fabrication. All that's left to do is the final welding. My little Miller 130XP mig isn't quite powerful enough for this task, so I'm going to borrow my buddy's Miller 211 mig. Once the final welding is complete, the plan is to spray a coat or two of industrial grade epoxy primer, and finish with black Monstaliner.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061598
04/24/13 04:20 PM
04/24/13 04:20 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
Damn Dave.... YOU'RE GOOD!!!
Re: MY JEEP BUILD THREAD [Re: Jeepmon] #1061599
04/24/13 10:12 PM
04/24/13 10:12 PM
Skypower Offline
Skypower  Offline
Very nice build you have there thanks for taking the to share with us. Hope to see that thing running around soon. I also live Tampa. I have black 69 Cuda with a Hemi in it, also should be on the road soon.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061600
04/25/13 04:16 PM
04/25/13 04:16 PM
Orlando Florida
blown572dart Offline
Orlando Florida
Very nice Dave. I sold my truck and ended up in a JK Door and couldn't be happier.
Re: MY JEEP BUILD THREAD [Re: blown572dart] #1061601
04/25/13 11:29 PM
04/25/13 11:29 PM
Tampa
Tampa
Finished building the under-tub mount/skid for the RCI fuel cell. Made out of steel angle, and I used 16 gauge aluminum diamond plate on the sides. The bottom is covered with a piece of 1/8" 6061-T6 aluminum plate.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061602
04/25/13 11:31 PM
04/25/13 11:31 PM
Tampa
Tampa
My tailgate had a slight inward curvature to it, and try as I might, I couldn't make it straight. So, I began looking for a replacement tailgate. I figured that if I'm going to the trouble of replacing it, I should do something cool, like replace it with an old school CJ fold down tailgate. After some searching on craigslist, I found a super nice one for $100. Best part was, it was only 20 minutes away from my house. The seller threw in the cable brackets too.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061603
04/25/13 11:32 PM
04/25/13 11:32 PM
Tampa
Tampa
I had to cut some access holes in the tub, in order to add some reinforcement behind the hinges. Instead of just using flat plate, I decided to use two pieces of 2" x 2" steel angle, cut 5-1/2" long. In addition to the hinge screws going through one side of the angle, when the tub comes off for body work and painting, I will drill holes and add bolts at the bottom, which will add more strength and support for the hinges. I'll make some sheet metal plates to cover the access openings.
Access holes.
Steel angle pieces for hinge reinforcement.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061604
04/25/13 11:32 PM
04/25/13 11:32 PM
Tampa
Tampa
I finished up the CJ tailgate installation tonight.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061605
04/25/13 11:33 PM
04/25/13 11:33 PM
Tampa
Tampa
The Poison Spyder cage kit came in today. This looks like fun.
I plan to add some additional bracing, tube gussets, and seat mount tubing.
I found this video from the guys on the TV show Truck U, talking about this cage kit.
http://www.youtube.com/watch?feature=player_embedded&v=IMLhbTDB8_s
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061606
04/26/13 07:25 PM
04/26/13 07:25 PM
Tampa
Tampa
Summit Racing has a great sale going on right now on Hooker Aero Chamber all stainless steel mufflers. These 2-1/2" mufflers normally run $169.00 each, I paid just $59.50 each!!!!
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061607
04/26/13 08:30 PM
04/26/13 08:30 PM
Tampa, FL
tpabayflyer Offline
tpabayflyer  Offline
Tampa, FL
Nice work Bud!! Are going with dual exhaust or a big single?
71 Challenger 528 Hemi project
09 Gr Cherokee 5.7 hemi in da house!!
Re: MY JEEP BUILD THREAD [Re: tpabayflyer] #1061608
04/26/13 09:34 PM
04/26/13 09:34 PM
Tampa
Tampa
Well, since I JUST showed a pic of TWO mufflers, that's an indication that I'm going with a full dual exhaust. I had originally started building a two into one system, but the guru at Performance Only felt that the shorty block hugger headers I had would hold back power, and he suggested long tube headers. I then decided to go all the way and build a full dual exhaust. It will be 3" after the collector, and reduces down to 2-1/2" right before the inlet side of the mufflers, and then 2-1/2" tailpipes.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061609
04/27/13 05:44 PM
04/27/13 05:44 PM
Tampa, FL
tpabayflyer Offline
tpabayflyer  Offline
Tampa, FL
Sounds good Mon!!!!! Pun intended! TBF
Re: MY JEEP BUILD THREAD [Re: tpabayflyer] #1061610
04/27/13 05:52 PM
04/27/13 05:52 PM
Tampa
Tampa
The LED stop, turn and tail lamps came in, along with the LED backup lamps.
With the help of a couple friends and some ratchet straps, I got started on the cage.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061611
04/27/13 10:02 PM
04/27/13 10:02 PM
Damn Dave.....your kick'n butt....looks awesome
Rickster
Re: MY JEEP BUILD THREAD [Re: rickstershemi] #1061612
04/28/13 12:36 AM
04/28/13 12:36 AM
Tampa
Tampa
Rickster
Thanks, Rick! The build process is a challenging journey, and I enjoy it. It keeps me out of the bars, and the wife always knows where I'm at, so its all good.
