Page 21 of 55 1 2 19 20 21 22 23 54 55
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061433
09/30/12 02:36 PM
09/30/12 02:36 PM
Tampa
DusterDave Offline OP
Tampa
I decided to cut my losses and ditch the CJ hood I had originally bought. Just way too many holes to patch. I searched craigslist last Friday, and found another hood in WAY better condition for $75. It did have two areas that needed some metal replacement, and a hole smaller than the size of a dime, but other than that, overall its in nice straight condition.
Here are the two larger spots that needed metal replacement, already welded up and ground down. I'm going to shoot a coat of epoxy primer on before doing the plastic filler work.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061434
10/02/12 02:48 PM
10/02/12 02:48 PM
Tampa, FL
tpabayflyer Offline
tpabayflyer  Offline
Tampa, FL
Man that Jeep is gonna be killer!
71 Challenger 528 Hemi project
09 Gr Cherokee 5.7 hemi in da house!!
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061435
10/02/12 09:00 PM
10/02/12 09:00 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Good product, the guy that owns the company is on the Jeep forum, he is a real piece of work. I have never bought from him or had a run in but just reading his post will ensure that I never use it. Real shame it's good stuff, my brother uses a lot of the chassis saver and it's holds up really well. Sorry.
I cant wait to see it on the tub.
Careful, your character's showing!
Re: MY JEEP BUILD THREAD [Re: mopar346] #1061436
10/02/12 10:56 PM
10/02/12 10:56 PM
Tampa
Tampa
You're talking about Eric! He doesn't bother me so much, probably because I'm from the NJ/NY area, and I came in contact with lots of guys like him.
Maybe this weekend, I'll wire wheel the rusty spots and hit them with the Chassis Saver. My next expenditure will be for the front shocks. I've got my sights on some Bilsteins, but not yet decided on which model.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061437
10/03/12 09:22 AM
10/03/12 09:22 AM
mopar346 Offline
mopar346  Offline
Why is everyone so sold on the Bilsteins? I am at the point with the axle swap where I have to get new ones and I would be curious how you came to your decision on brand and then of course model. I don't really have an opinion or knowledge on the subject.
Re: MY JEEP BUILD THREAD [Re: mopar346] #1061438
10/03/12 01:35 PM
10/03/12 01:35 PM
Tampa
Tampa
There's no denying it, Bilstein has a great reputation for building high quality, high performance shocks. Read this, and you'll see why people choose Bilsteins. http://www.eshocks.com/bil_ORin.asp?Manf=All>
I've decided to go with 5165's in the front, and 5125's for the rear. I figure with the all iron V8 up front, the front shocks will get more of a workout, so I opted for the 5165 reservoir shocks. The rear won't see as much weight, (and to save a little money) I went with the 5125's. Since I need longer than stock length shocks, both were a good choice, since they come in custom lengths.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061439
10/04/12 08:03 PM
10/04/12 08:03 PM
Tampa
Tampa
Just great. The Bilstein 5165's that I want are on manufacturer's back order for 4 to 6 weeks, and you know how those estimates can be revised....longer!
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061440
10/04/12 08:25 PM
10/04/12 08:25 PM
Lehigh Acres, Florida
rickstershemi Offline
Exactly which part # are you looking for Dave?
Rickster
Re: MY JEEP BUILD THREAD [Re: rickstershemi] #1061441
10/04/12 10:02 PM
10/04/12 10:02 PM
Tampa
Tampa
Rickster
Rick, it's 25-187762.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061442
10/04/12 10:24 PM
10/04/12 10:24 PM
Rickster
http://www.allshocks.com/bilstein/html/s...CFQcGnQod6B0Apg
Re: MY JEEP BUILD THREAD [Re: rickstershemi] #1061443
10/04/12 10:50 PM
10/04/12 10:50 PM
Tampa
Tampa
Rickster
I called allshocks.com, eshocks.com, shockwarehouse.com, 4wd.com, offroadwarehouse.com, and polyperformance.com. Nobody has them in stock. But, thanks for looking!
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061444
10/04/12 10:53 PM
10/04/12 10:53 PM
Rickster
Re: MY JEEP BUILD THREAD [Re: rickstershemi] #1061445
10/06/12 01:11 PM
10/06/12 01:11 PM
Tampa
Tampa
On shockwarehouse.com, I found a spreadsheet of a huge list of Bilstein part numbers that are currently on backorder, and its incomplete at that, because the shock I want isn't on that list. Makes me wonder what in hell is going on at Bilstein. From what allshocks.com hinted in an email, it sounds like supply chain problems.
I would consider Fox reservoir shocks for the front, but I don't want spherical rod ends, I want the stock type rubber bushings like the 5165 has. Anyway, I've put in an order for the 5165's, so I'll get my front shocks one of these months (I hope).
In the meantime, I placed an order for the Bilstein 5125's for the rear, a Northern aluminum crossflow radiator that is custom fit for a CJ, and an Chevy HHR fan/shroud assembly from rockauto.com.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061446
10/08/12 11:31 PM
10/08/12 11:31 PM
mopar346 Offline
mopar346  Offline
thanks, that was a good read
Re: MY JEEP BUILD THREAD [Re: mopar346] #1061447
10/12/12 07:35 PM
10/12/12 07:35 PM
Tampa
Tampa
The Northern rad came in today. After having to fabricate so many brackets and stuff on the Duster, its refreshing to be able to buy something and just bolt it on.
Originally, I was going to go with an HHR fan assembly from rockauto.com, but after much reading on the 'net, I decided to go with a new 1995 Ford Thunderbird electric fan assembly from rockauto. It was only about $12 more than the HHR fan, and it has a two speed fan motor, as opposed to the HHR's single speed motor. It will be thermostatically controlled by a DCC controller. The T-Bird fan is basically the same as the vaunted Lincoln Mark 8 fan, which is claimed to be slightly weaker than a Category 4 hurricane. The fan is a monster 18" in diameter, and since the fin area of the rad is 18-1/8" X 19-1/4", it is absolutely the biggest fan I could possibly fit.
To prevent rust from forming, and to stop rust that may be present, I coated the hard to reach insides of the hood structures with Eastwood Internal Frame Coating. I then sprayed two coats of epoxy primer on the hood, followed by 3 coats of high build primer.
I should be receiving the completed engine by the end of this month. Once its back at DusterDave HQ, progress on other parts and subsystems of the Jeep will really start to move along.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061448
10/14/12 11:46 PM
10/14/12 11:46 PM
Delray beach, Florida
P
Performance Only Offline
P
It's looking good Dave. Very nice progress.
here's a few pictures of the engine progress.
cam bearing and cam installed.
machine shop owner and engine builder
Re: MY JEEP BUILD THREAD [Re: Performance Only] #1061449
10/14/12 11:47 PM
10/14/12 11:47 PM
P
P
another.
Re: MY JEEP BUILD THREAD [Re: Performance Only] #1061450
10/14/12 11:48 PM
10/14/12 11:48 PM
P
P
rings all file fit and pistons ready to go.
Re: MY JEEP BUILD THREAD [Re: Performance Only] #1061451
10/14/12 11:50 PM
10/14/12 11:50 PM
P
P
pistons in the holes. we're getting there.
Re: MY JEEP BUILD THREAD [Re: Performance Only] #1061452
10/14/12 11:51 PM
10/14/12 11:51 PM
P
P
time to install the timing chain and degree that .900 lift roller,
