98 Dakota with 2.5 and manual tranny showing 0121 code #1060966
08/24/11 10:32 AM
08/24/11 10:32 AM
70RT Offline OP
70RT  Offline OP
code says voltage dif between tsp and map. I have changed the tps. Check engine light gone, but still have infrequent cruising stumble/power loss. Should I change the map?
Re: 98 Dakota with 2.5 and manual tranny showing 0121 code [Re: 70RT] #1060967
08/24/11 12:09 PM
08/24/11 12:09 PM
ill
dennismopar73 Offline
ill
yes change both,, also check the connectors, for corrosion,
or broken /bare grounding,
Re: 98 Dakota with 2.5 and manual tranny showing 0121 code [Re: dennismopar73] #1060968
08/24/11 01:55 PM
08/24/11 01:55 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
You might find you have a leak in the little map line.
On a v8 it's a little rubber elbow piece if memory serves correct that comes out of the bottom of the map and goes to a nippple on the TB. Sometimes people move this to the manifold with a crappy hose and this causes problems too.
Dont know what it is on the 4 cyl but might be similar.
If there is a leak in that, it could cause a problem like you describe.
Re: 98 Dakota with 2.5 and manual tranny showing 0121 code [Re: POS Dakota] #1060969
08/24/11 05:52 PM
08/24/11 05:52 PM
70RT Offline OP
70RT  Offline OP
Thanks guys for your help I'll try both.
