Tire pressure with tubes? #1060905
08/24/11 08:26 AM
08/24/11 08:26 AM
tboomer Offline OP
tboomer  Offline OP
We may go racing this weekend at Tri-State here in Iowa. I have not been out since I had tubes put in both rear slicks. The tires are M.T. 31x15x10.5ws..I was running 9 to 9.5 pounds without tubes. I assume that I should stay the same? Thanks!! Ted
Re: Tire pressure with tubes? [Re: tboomer] #1060906
08/24/11 08:33 AM
08/24/11 08:33 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Ted I would start out at the same pressure but with
the tubes they will stiffen up the side walls... you'll
need to play with the air to get your best launch...
have fun... go fast
Re: Tire pressure with tubes? [Re: MR_P_BODY] #1060907
08/24/11 08:39 AM
08/24/11 08:39 AM
tboomer Offline OP
tboomer  Offline OP
Thanks,Mike! I will try 9# to start..I will also leave the 3400 chip in for the brake. It is supposed to be a nice day Saturday. Sure would be nice to go a couple of rounds to get my confidence back!
Re: Tire pressure with tubes? [Re: tboomer] #1060908
08/24/11 08:49 AM
08/24/11 08:49 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Ted I found that on my car the lower the launch RPM was
the higher I needed the tire pressure... high RPM =
lower tire pressure... if I launch at low RPM with the
tires at 7.0# it would cup the tires big time
Re: Tire pressure with tubes? [Re: MR_P_BODY] #1060909
08/24/11 09:02 AM
08/24/11 09:02 AM
tboomer Offline OP
tboomer  Offline OP
I don't think there will be time to play with it..Two time trials...I think than right to eliminations...
Re: Tire pressure with tubes? [Re: tboomer] #1060910
08/24/11 09:24 AM
08/24/11 09:24 AM
PA
moparacer Offline
moparacer  Offline
PA
People still run tubes?
I think I seen a actual tube that they used to install in tires at the Smithsonian once....
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Tire pressure with tubes? [Re: moparacer] #1060911
08/24/11 09:29 AM
08/24/11 09:29 AM
tboomer Offline OP
tboomer  Offline OP
I punctured one slick a while back...The hole was too close to the sidewall for a patch..
Re: Tire pressure with tubes? [Re: moparacer] #1060912
08/24/11 09:38 AM
08/24/11 09:38 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Makes my slicks last longer
Re: Tire pressure with tubes? [Re: moparacer] #1060913
08/24/11 10:43 AM
08/24/11 10:43 AM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Yep, some of us still do.
Re: Tire pressure with tubes? [Re: moparacer] #1060914
08/24/11 11:56 AM
08/24/11 11:56 AM
NC
440Jim Offline
440Jim  Offline
NC
That is funny.
But putting tubes in my slicks was the best thing I ever did for my application.
I was killing the side wall on my slicks around the 100 pass mark. Then I added inner tubes, changed from 12" wide rims to 14", and this allowed increasing tire pressure to 11 psi. Now I get over 200 passes (225 on the last set) on the slicks.
Re: Tire pressure with tubes? [Re: 440Jim] #1060915
08/24/11 12:05 PM
08/24/11 12:05 PM
Oklahoma City, OK
Dave64 Offline
Dave64  Offline
Oklahoma City, OK
Tubes are your friends.
Re: Tire pressure with tubes? [Re: Dave64] #1060916
08/24/11 04:37 PM
08/24/11 04:37 PM
Westbury, NY
bumps440 Offline
super gas
bumps440  Offline
super gas
Westbury, NY
I use tubes also. Find better consistancy and stability .
Re: Tire pressure with tubes? [Re: bumps440] #1060917
08/24/11 05:46 PM
08/24/11 05:46 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I dont like to hijack but your car is very quick for an iron head 440, would you be willing to divulge the spec. You can pm me if you wish.
Oh Ted, i run tubes as well.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Tire pressure with tubes? [Re: deaks] #1060918
08/24/11 05:52 PM
08/24/11 05:52 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
wow,,you guys run low tire pressures compared to what i am used to.
I was running 14lb,,,,but dropped to 12 recently,,,maybe I need to experiment a bit more,,eg 11 like 440jim.
never considered running less than 10,,does the car "wave" around at the high end of the track ?
I run tubes in mine,,,fyi,
Re: Tire pressure with tubes? [Re: 69CHARGERMD] #1060919
08/24/11 07:17 PM
08/24/11 07:17 PM
Westbury, NY
bumps440 Offline
super gas
bumps440  Offline
super gas
Westbury, NY
you are on the right track
run the most pressure that will still hook the car.
when you dropped the pressure what happned?
I run about 11.5 in mine.
Re: Tire pressure with tubes? [Re: bumps440] #1060920
08/24/11 08:20 PM
08/24/11 08:20 PM
Az
Crizila Offline
Crizila  Offline
Az
10-4 on that one. Improves consistancy and makes the car handle better. Inner tubes for you slicks - don't leave home withoutem!
Fastest 300
Re: Tire pressure with tubes? [Re: Crizila] #1060921
08/24/11 08:32 PM
08/24/11 08:32 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Some people would rather put air in between rounds, in the staging lanes and stop three times on the way home, I run new slicks till the side walls start to leak, then in goes the tubes.
Re: Tire pressure with tubes? [Re: rowin4] #1060922
08/24/11 08:42 PM
08/24/11 08:42 PM
Az
Crizila Offline
Crizila  Offline
Az
Es-no-my-shab-mon! That's what wives are for.
Fastest 300
Re: Tire pressure with tubes? [Re: tboomer] #1060923
08/24/11 10:09 PM
08/24/11 10:09 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
12.2x31.25 Phoenix with tubes...9.5-10lbs.
Nautilus Racing-
Re: Tire pressure with tubes? [Re: 69CHARGERMD] #1060924
08/24/11 11:04 PM
08/24/11 11:04 PM
NC
440Jim Offline
440Jim  Offline
NC
There are lots of factors for tire pressure. For example:
Car weight (heavier = higher pressure)
Tire size (smaller = higher pressure)
Launch torque(higher = higher pressure)
Chassis setup, rim width/tire width, weight distribution, weight transfer, instant center... (depends)
etc.
