Re: Tire pressure with tubes?
[Re: tboomer]
#1060906
08/24/11 08:33 AM
08/24/11 08:33 AM
Posts: 52,972 Romeo MI
MR_P_BODY
We may go racing this weekend at Tri-State here in Iowa. I have not been out since I had tubes put in both rear slicks. The tires are M.T. 31x15x10.5ws..I was running 9 to 9.5 pounds without tubes. I assume that I should stay the same? Thanks!! Ted
Ted I would start out at the same pressure but with the tubes they will stiffen up the side walls... you'll need to play with the air to get your best launch... have fun... go fast
[Re: tboomer]
#1060908
08/24/11 08:49 AM
08/24/11 08:49 AM
MR_P_BODY
Thanks,Mike! I will try 9# to start..I will also leave the 3400 chip in for the brake. It is supposed to be a nice day Saturday. Sure would be nice to go a couple of rounds to get my confidence back!
Ted I found that on my car the lower the launch RPM was the higher I needed the tire pressure... high RPM = lower tire pressure... if I launch at low RPM with the tires at 7.0# it would cup the tires big time
[Re: moparacer]
#1060912
08/24/11 09:38 AM
08/24/11 09:38 AM
MR_P_BODY
People still run tubes?
I think I seen a actual tube that they used to install in tires at the Smithsonian once....
Makes my slicks last longer
[Re: moparacer]
#1060913
08/24/11 10:43 AM
08/24/11 10:43 AM
Posts: 3,428 Dandridge TN
Dabee
Dandridge TN
Yep, some of us still do.
[Re: moparacer]
#1060914
08/24/11 11:56 AM
08/24/11 11:56 AM
Posts: 16,925 NC
440Jim
NC
That is funny. But putting tubes in my slicks was the best thing I ever did for my application.
I was killing the side wall on my slicks around the 100 pass mark. Then I added inner tubes, changed from 12" wide rims to 14", and this allowed increasing tire pressure to 11 psi. Now I get over 200 passes (225 on the last set) on the slicks.
[Re: bumps440]
#1060917
08/24/11 05:46 PM
08/24/11 05:46 PM
Posts: 3,210 robin hood country
deaks
robin hood country
I dont like to hijack but your car is very quick for an iron head 440, would you be willing to divulge the spec. You can pm me if you wish. Oh Ted, i run tubes as well. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: deaks]
#1060918
08/24/11 05:52 PM
08/24/11 05:52 PM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
wow,,you guys run low tire pressures compared to what i am used to. I was running 14lb,,,,but dropped to 12 recently,,,maybe I need to experiment a bit more,,eg 11 like 440jim. never considered running less than 10,,does the car "wave" around at the high end of the track ? I run tubes in mine,,,fyi,
[Re: Crizila]
#1060921
08/24/11 08:32 PM
08/24/11 08:32 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
Some people would rather put air in between rounds, in the staging lanes and stop three times on the way home, I run new slicks till the side walls start to leak, then in goes the tubes.
[Re: tboomer]
#1060923
08/24/11 10:09 PM
08/24/11 10:09 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
12.2x31.25 Phoenix with tubes...9.5-10lbs.
[Re: 69CHARGERMD]
#1060924
08/24/11 11:04 PM
08/24/11 11:04 PM
Posts: 16,925 NC
440Jim
NC
There are lots of factors for tire pressure. For example: Car weight (heavier = higher pressure) Tire size (smaller = higher pressure) Launch torque(higher = higher pressure) Chassis setup, rim width/tire width, weight distribution, weight transfer, instant center... (depends)
etc.
