Tires spinning on Rims, Whats the Fix #1060765
08/23/11 11:05 PM
08/23/11 11:05 PM
Greensburg, Pa
Mpetros Offline OP
Mpetros  Offline OP
Greensburg, Pa
Tried Moroso Tire Screws,
Tires still tried to move, bent all the Screws
Took out the Screws and Tried High Tack, Tires still moved
Cleaned off High Tack and Used 3M window Weld this last time. One Tire Stuck and the other Moved about an Inch.
Any Suggestions?
Re: Tires spinning on Rims, Whats the Fix [Re: Mpetros] #1060766
08/23/11 11:13 PM
08/23/11 11:13 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
how big are the screws?? how many did u use??
Re: Tires spinning on Rims, Whats the Fix [Re: Mpetros] #1060767
08/23/11 11:22 PM
08/23/11 11:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Any Suggestions?
I didnt like the Moroso screws so I went to a fastener
place and got harder screws PLUS you do need more screws
if you bent those... I run 1.21 60' on the norm but
have been 1.19.... actually more screws is better
anyways so it keeps a flatter foot print on the track...
also make sure they are going into the big part of
the bead
Re: Tires spinning on Rims, Whats the Fix [Re: Mpetros] #1060768
08/24/11 12:56 AM
08/24/11 12:56 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
More air in the tires and or more screws.
Re: Tires spinning on Rims, Whats the Fix [Re: goldmember] #1060769
08/24/11 01:58 AM
08/24/11 01:58 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
it's only a problem if you run tubes. i was using tek screws & only on the inside & installing them with the cordless drill but last season i ran nothing & they only moved 3" before they stopped. i run 1.4 60's & swap wheels side for side at half season. even after i swaped sides they didn't move & i'm only running 7.5lbs pressure.
Re: Tires spinning on Rims, Whats the Fix [Re: rebel] #1060770
08/24/11 01:15 PM
08/24/11 01:15 PM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
Convert wheels to bead locks and never slip a tire again! Of course that's not a cheap conversion, but you can add up to 1" of rim width at the same time.
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
Re: Tires spinning on Rims, Whats the Fix [Re: Mpetros] #1060771
08/25/11 03:16 PM
08/25/11 03:16 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Whats the combo...tire size wheel width, power/weight????
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Tires spinning on Rims, Whats the Fix [Re: W.I.N. Racing] #1060772
08/25/11 04:14 PM
08/25/11 04:14 PM
ill
dennismopar73 Offline
ill
i dont run any screws,, but i dont run a 1.20 -130 60 either,,
but a run 1.40s never had one even think about moving,
several guys who run deep into 9 s with no scews
but if youres is moving ,, and screws and sealer not working , have top get bead lock,
Re: Tires spinning on Rims, Whats the Fix [Re: dennismopar73] #1060773
08/25/11 05:30 PM
08/25/11 05:30 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I run the 1022 tires no tubes no screws no slippage 1.02-1.04 60'. I clean the rims on the inside rather they need it or not every time the tires come off.Almost forgot if the tire is not new also clean the bead.Only let them use soap & water when mounting them.
This is about the best picture I have of rear slicks,but maybe you can see I do not run any screws. Maybe a good cleaning of the wheels & tires will solve your problem.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Tires spinning on Rims, Whats the Fix [Re: MRMOPAR622] #1060774
08/25/11 06:03 PM
08/25/11 06:03 PM
MD
HEMI472 Offline
HEMI472  Offline
MD
bead lock wheels
