Tires spinning on Rims, Whats the Fix
#1060765
08/23/11 11:05 PM
08/23/11 11:05 PM
Posts: 295 Greensburg, Pa
Mpetros
Greensburg, Pa
Tried Moroso Tire Screws, Tires still tried to move, bent all the Screws Took out the Screws and Tried High Tack, Tires still moved Cleaned off High Tack and Used 3M window Weld this last time. One Tire Stuck and the other Moved about an Inch. Any Suggestions?
Re: Tires spinning on Rims, Whats the Fix
[Re: Mpetros]
#1060767
08/23/11 11:22 PM
08/23/11 11:22 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I didnt like the Moroso screws so I went to a fastener place and got harder screws PLUS you do need more screws if you bent those... I run 1.21 60' on the norm but have been 1.19.... actually more screws is better anyways so it keeps a flatter foot print on the track... also make sure they are going into the big part of the bead
[Re: rebel]
#1060770
08/24/11 01:15 PM
08/24/11 01:15 PM
Posts: 684 St. Charles, MO.
Slingshot383
St. Charles, MO.
Convert wheels to bead locks and never slip a tire again! Of course that's not a cheap conversion, but you can add up to 1" of rim width at the same time.
1994 Undercover Chassis 125" altered
stack injected big block, soon blown and injected
Member of The Torque and Recoil Club
[Re: Mpetros]
#1060771
08/25/11 03:16 PM
08/25/11 03:16 PM
Posts: 2,115 Byron, NY
W.I.N. Racing
Byron, NY
Whats the combo...tire size wheel width, power/weight????
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#1060772
08/25/11 04:14 PM
08/25/11 04:14 PM
Posts: 2,177 ill
dennismopar73
ill
i dont run any screws,, but i dont run a 1.20 -130 60 either,, but a run 1.40s never had one even think about moving, several guys who run deep into 9 s with no scews but if youres is moving ,, and screws and sealer not working , have top get bead lock,
[Re: dennismopar73]
#1060773
08/25/11 05:30 PM
08/25/11 05:30 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
I run the 1022 tires no tubes no screws no slippage 1.02-1.04 60'. I clean the rims on the inside rather they need it or not every time the tires come off.Almost forgot if the tire is not new also clean the bead.Only let them use soap & water when mounting them.
This is about the best picture I have of rear slicks,but maybe you can see I do not run any screws. Maybe a good cleaning of the wheels & tires will solve your problem.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: MRMOPAR622]
#1060774
08/25/11 06:03 PM
08/25/11 06:03 PM
Posts: 781 MD
HEMI472
MD
