Page 1 of 6 1 2 3 4 5 6
SB Oil Pump. Anyone ever done this? #1060525
08/23/11 09:04 PM
08/23/11 09:04 PM
Muncie
Racebuddy Offline OP
Muncie
My motor starving for oil.
The book "How to build SB engines says that the pick up tube is too small.
Will two pick up tubes work.
lets hear all your views, Please
Re: SB Oil Pump. Anyone ever done this? [Re: Racebuddy] #1060526
08/23/11 09:15 PM
08/23/11 09:15 PM
Locomotion Offline
Locomotion  Offline
Lots of variables - RPM, clearances, etc. Quality and viscosity of oil can also be factored in. But I've been using stock p/u's in my current car since 1999 with Amsoil viscosities as low as 5w-30 with no issues. 6,700+ regularly and the pump is OEM pressure & volume!
Oops! Make that 5w-20.
Very mild porting/polishing of the OEM passage in the pump and main cap can help a bit.
Re: SB Oil Pump. Anyone ever done this? [Re: Locomotion] #1060527
08/23/11 09:24 PM
08/23/11 09:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Same here... stock pick up but with the pump holes
blended... running 7800 rpm
Re: SB Oil Pump. Anyone ever done this? [Re: MR_P_BODY] #1060528
08/23/11 10:06 PM
08/23/11 10:06 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
yep same here and I have more oil pressure than I need and it never drops.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: SB Oil Pump. Anyone ever done this? [Re: Racebuddy] #1060529
08/23/11 10:06 PM
08/23/11 10:06 PM
AndyF Offline
AndyF  Offline
Dual pickups used to be a common trick but I haven't seen it for a few years now. Someone used to sell a dual pickup kit but I don't think it is available anymore?
Some people port the oil pump and use a larger pickup tube.
Re: SB Oil Pump. Anyone ever done this? [Re: Racebuddy] #1060530
08/23/11 10:19 PM
08/23/11 10:19 PM
There is a reason for all things mechanically that fail, why is your motor running out of oil? Fix that and go on and have some fun. Maybe we need some more information as far as what your doing,IE drag racing, street, truck pulling, circle racing or?
Re: SB Oil Pump. Anyone ever done this? [Re: Cab_Burge] #1060531
08/23/11 10:49 PM
08/23/11 10:49 PM
Muncie
Muncie
Its a 360, running 11's in a Rambler.
I thought about the oil gear's clearance on the oil pump face plate.
Why is it starving for oil? I don't know but over the last 25 years I have lost a BUNCH of motors due to oil starvation.
Trust me i have been through it all on preparing engines to live but still sometimes it just isn't in the cards for them to stay together.
This was a brand new 360 complete rotating kit. I think the clevite's are crap. cast cranks don't like them. Using King aluminum bearings only from now on, BUT...
What about the my pump with 2 pick up tubes?? run thinner oil and it could be a go??
Re: SB Oil Pump. Anyone ever done this? [Re: MR_P_BODY] #1060532
08/23/11 10:53 PM
08/23/11 10:53 PM
Muncie
Muncie
I have also massaged out the orifice of the main cap and pump inlet on engines before.
Still the latest "How To" book says that the pick up tubes are too small.
Yes I am aware that many engines run good and live with stock tube sizes but what I am after is OVERKILL ON OILING !!!
Givin it a shot unless someone knows for sure that this is a big NO NO
Thanks fellas
Re: SB Oil Pump. Anyone ever done this? [Re: Racebuddy] #1060533
08/23/11 10:57 PM
08/23/11 10:57 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
My first question would be what oil pan are you using? I and several friends have used a blueprinted stock pump in many combo's with success. Are you using a Hi Vol pump and the oil not draining back fast enough?
Alan Jones
Re: SB Oil Pump. Anyone ever done this? [Re: LA360] #1060534
08/23/11 11:02 PM
08/23/11 11:02 PM
Muncie
Muncie
Well that is an interesting question, 'Is it not draining back to the pan?" How would I know ??
Its a stock truck pan. no mods to it.
11 second car, about 6500 spinning, foot brakin.
The bearings show flaking and the typical signs of starvation.
New HV pump
Re: SB Oil Pump. Anyone ever done this? [Re: Racebuddy] #1060535
08/23/11 11:07 PM
08/23/11 11:07 PM
SoCal
Brian Hafliger Offline
SoCal
New HV pump
Is it baffled????
Brian Hafliger
Re: SB Oil Pump. Anyone ever done this? [Re: Brian Hafliger] #1060536
08/23/11 11:12 PM
08/23/11 11:12 PM
Muncie
Muncie
no baffles in pan. nothing done in valley to aid oil return.
hard to get my head around the possibility that 6 quarts of oil can't find its way back to the pan and get stuck up top.
will the pump work??
Re: SB Oil Pump. Anyone ever done this? [Re: Racebuddy] #1060537
08/23/11 11:13 PM
08/23/11 11:13 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
It takes a lot of oil to keep up with the 360 main bearings. I have had shops try to set it up with too much clearance and it would pump the pan dry with a high volume pump. Alway ran a high volume with the 360 mains I ran. I would however try a standard pump with 340 mains.
Are you sure the plug in the drivers side rear of the oil galley is in place. I have seen many left out and had big problems. I also ran a roller cam with the oil galley tubed. Ran Harland SHarps and restricted oil to the heads also. Holley #66 main jet works great on the Passenger side and #72 on the drivers side. The cam I ran had the journal ground to oil the rockers full time. Spun that puppy 8400 in the quarter with no problems.
I think you have clearance extremes or oil control problems that are not getting the oil back to the pan. Wait, truck pans are only 6 quarts. Will a KEVCO pan work they are bigger. Probably 8 quarts.
Another thing if you are running too much ignition timing you may be beating the oil out of the bearings.
Leon
Re: SB Oil Pump. Anyone ever done this? [Re: Leon441] #1060538
08/23/11 11:34 PM
08/23/11 11:34 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
you sure dont need 2 pick ups if it is sucking the pan dry with one. So if it happens to a lot of your engines, then you are doing something wrong. Too many small block combos here running the same rpm's, with more than you got going on, and running strong. Just my opinion.
Re: SB Oil Pump. Anyone ever done this? [Re: Brian Hafliger] #1060539
08/23/11 11:38 PM
08/23/11 11:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
New HV pump
Is it baffled????
True ... all the pans I make have baffles to keep
the oil at the pick up
Re: SB Oil Pump. Anyone ever done this? [Re: MR_P_BODY] #1060540
08/24/11 12:13 AM
08/24/11 12:13 AM
Gilbert, AZ
Aspen7695 Offline
Aspen7695  Offline
Gilbert, AZ
I believe that a high volume pump is great as long as you have a large pan. Several people I know were contunually spinning bearings when they ran a high volume pump with a stock pan. Once I got them to use a stock pump with the stock pan their bearing problems went away.
I run a 360 in my stock eliminator Duster that runs low to mid 11's. I run a stock Melling pump. I shift at 6600 and go thru the lights at 7000. I run 5-30 Valvoline synthetic oil. I have 40 lbs at idle and 65 lbs when I go thru the lights.
Raul
Re: SB Oil Pump. Anyone ever done this? [Re: Racebuddy] #1060541
08/24/11 12:27 AM
08/24/11 12:27 AM
New York
polyspheric Offline
polyspheric  Offline
New York
If either one loses prime, the other one stops pulling oil.
Boffin Emeritus
Re: SB Oil Pump. Anyone ever done this? [Re: polyspheric] #1060542
08/24/11 12:32 AM
08/24/11 12:32 AM
Delray beach, Florida
P
Performance Only Offline
P
it looks like your treating the symptom and not the root cause. solve the oil pan issue, the drain back issue and make sure you have the proper oil clearance for the bearings and the stock size pickup will be more than adequate.
machine shop owner and engine builder
Re: SB Oil Pump. Anyone ever done this? [Re: Performance Only] #1060543
08/24/11 02:58 AM
08/24/11 02:58 AM
Canada BC
Steve Barton Offline
Canada BC
I an running a R3 block with a Kevko oil pan, wile I was priming the engine I had only put 4 liters of oil in the pan and I sucked the pan dry. Of cores the engine is cold the oil is cold so very slow drain back. But at the track with the 7 liters in it I was loosing oil pressure on de-cell.So knowing there is at least half the oil traveling through the engine and only half in the pan, if you are lucky, I added another liter to the pan and solved the problem.this can only mean I was sucking air on de-cell wile the oil was forced forward. it just goes to show you there is very little oil in the pan at hi rpm's
Oil level and oil pump pick up adjustment are critical.
Homepage Pic's http://www.bluemelon.com/dodgeman/ Steve. New best 1.40 60' 9.99 Et 132.8 mph
Re: SB Oil Pump. Anyone ever done this? [Re: Steve Barton] #1060544
08/24/11 06:00 AM
08/24/11 06:00 AM
Guitar Jones Offline
http://www.forabodiesonly.com/mopar/showthread.php?t=103623
BTW there is 9 quarts of oil in the Canton 7 quart pan and the level still shows to be 1/2 quart low on the dipstick from the stock oil level.
