okay im checking my compression on my 440 anyway heres the problem i checked 1 st 20lbs the next one 160 then the other were all reading basicly nothing on the gauge. I re checked the first two and they read nothing the as the rest so i thought its probably my gauge so i checked my compression on my snowmobile and the gauge works fine thanks bryan.
the reason i was checking my compression was my car has a terrible miss under load i have re timed the car three diffrent times this year alone. Then i put a bigger carb on it my combo is a 10.1 comp speed pro pistons 452 heads 484 comp cam elderbrock performer intake mp igition when idleing or reving up in neutrual. It sounds great its once you get out on the road give the pedal it just starts to miss bad i am going to pick up another gauge this week.
