Comp 829 roller lifter dimensions #1060188
08/23/11 12:38 PM
08/23/11 12:38 PM
closer to Canadian beer!
torkrules Offline OP
I'm neurotic
I'm neurotic
Was wondering if anyone could measure a Comp 829 roller lifter for me since all of mine are in the engine. Trying to souce some alternatives.
What I'm looking for is a dimension from the bottom of the roller wheel to the bottom of the push rod cup (overall length from roller bottom to top of lifter body minus the depth from the top of lifter body to bottom of pushrod seat), and also the distance from the bottom of the roller to the center of the link bar stud.
Width of the link bar would be helpfull as well.
Thanks in advance!
Re: Comp 829 roller lifter dimensions [Re: torkrules] #1060189
08/23/11 03:05 PM
08/23/11 03:05 PM
North Sweden
RT540 Offline
RT540  Offline
North Sweden
Here you go
Re: Comp 829 roller lifter dimensions [Re: torkrules] #1060190
08/23/11 03:49 PM
08/23/11 03:49 PM
I'm neurotic
I'm neurotic
WOW! Above and beyond the call of duty! Thank You very Much!
Re: Comp 829 roller lifter dimensions [Re: torkrules] #1060191
08/23/11 04:02 PM
08/23/11 04:02 PM
North Sweden
RT540 Offline
RT540  Offline
North Sweden
The drawing is from 2002, and at that time, I didnīt know who made the lifters in my 540.
It was easy this time, I just attached the jpg today.
Nice to be able to help out today
Re: Comp 829 roller lifter dimensions [Re: RT540] #1060192
08/23/11 05:36 PM
08/23/11 05:36 PM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
Here you go
Re: Comp 829 roller lifter dimensions [Re: RT540] #1060193
08/24/11 07:12 AM
08/24/11 07:12 AM
I'm neurotic
I'm neurotic
In comps catalog they list the pushrod seat at 1.7". Can't figure out where they get this number from. No matter how I do the math I come up with 1.4.
Re: Comp 829 roller lifter dimensions [Re: torkrules] #1060194
08/24/11 02:57 PM
08/24/11 02:57 PM
North Sweden
RT540 Offline
RT540  Offline
North Sweden
My drawing got 1.44" is that what you are referring to ?
I didnīt use a pushrod back in 2002, today I used a 5/16" ball to ball pushrod with a 300mm Mitutoyo, and came up to 1.50".
This is a used lifter, and the wheel rocks a little in the neddle bearing.
Hope this helps
Tom
Re: Comp 829 roller lifter dimensions [Re: RT540] #1060195
08/25/11 12:10 AM
08/25/11 12:10 AM
Hamilton,Ont
72chrgrally Offline
72chrgrally  Offline
Hamilton,Ont
Hey John I checked and all I have is 3 sets of solid lifters, sorry man.
Steve
Photobucket sucks
Re: Comp 829 roller lifter dimensions [Re: torkrules] #1060196
08/25/11 12:18 AM
08/25/11 12:18 AM
Albert Lea, MN
GTX5877 Online work
GTX5877  Online Work
Albert Lea, MN
The spec in Comps catalog includes a 5/16" ball- .310" which would give you approx. 1.4" "effective length".
1967 Dart GTS 426 Gen III Hemi
1968 Hemi Cuda 572 SS/AH Clone
1988 Chrysler LeBaron Coupe S/S
2003 Dodge Ram 1500 4dr SLT lowered
2012 Ram 1500 2wd Lowered
1970-1/2 Camaro Z-28
1974 VW Karman-Ghia
Re: Comp 829 roller lifter dimensions [Re: GTX5877] #1060197
08/25/11 01:13 PM
08/25/11 01:13 PM
North Sweden
RT540 Offline
RT540  Offline
North Sweden
I measured four more lifters today, and they are all between 1.49 to 1.50" from wheel to bottom of cup.
First I meas. the pushrod, then all togheter and subtract the pushrod length.
