Carb Spacer 383 70 RoadRunner ????? #1059970
08/23/11 11:32 AM
08/23/11 11:32 AM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
383 Edlebrock CH4B intake and edlebrock carb. The car has airgrabber and it is a 70 RR. How thick of a spacer will work on this and clear the air grabber? I need to run a spacer to keep it from perking all my gas out. I got a 1/2" one and it seems like it is hitting when I close the hood. I thought that this intake was the same height as the stock one. i just can't aford to bust my air grabber parts up. Thanks Ronnie
Re: Carb Spacer 383 70 RoadRunner ????? [Re: okie] #1059971
08/23/11 09:59 PM
08/23/11 09:59 PM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
Re: Carb Spacer 383 70 RoadRunner ????? [Re: okie] #1059972
08/24/11 12:01 AM
08/24/11 12:01 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
sounds like you have your own answer, not trying to be a smart a$$, but I'd guess less than a 1/2"
Re: Carb Spacer 383 70 RoadRunner ????? [Re: okie] #1059973
08/24/11 12:06 AM
08/24/11 12:06 AM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
If you haven't done it already, block the heat crossover in the intake.
Re: Carb Spacer 383 70 RoadRunner ????? [Re: okie] #1059974
08/24/11 12:10 AM
08/24/11 12:10 AM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
