#1059729 - 08/22/11 10:01 PM Merge Collectors
1967Valiant Offline
Loc: NC
So below are the headers Mr P speced for me. I am having a problem with collector size. 3.5 inch small side easy to get exhaust adapters for, 4 inch big side and cant find any adapters ie neck downs to exhaust mufflers 3.5 inch, any advice on which to go with.
3 step
1st pri dia 1.986 ... length 18.2 to 19.6
2nd pri dia 2.111 ... length 9.1 to 9.8
3rd pri dia 2.236 ... length 9.1 to 9.8
same collector ... stay on the larger end of spec
all dimensions of tubing are OD with a wall thickness
of .062
collector dia 3.616 to 3.866
#1059730 - 08/23/11 03:47 AM Re: Merge Collectors [Re: 1967Valiant]
1967Valiant Offline
Loc: NC
bump
#1059731 - 08/23/11 08:04 AM Re: Merge Collectors [Re: 1967Valiant]
ro23car Offline
Loc: s e mich
go to some semi truck site they have them. 4 states in joplin mo,chrome depot in mantua ohio.
#1059732 - 08/23/11 09:17 AM Re: Merge Collectors [Re: 1967Valiant]
BobR Offline
Loc: Left Coast
Burns Stainless.
#1059733 - 08/23/11 10:18 AM Re: Merge Collectors [Re: BobR]
Dunnuck Racing Offline
mopar addict
Loc: Northern Indiana
More often than not,if a merge collector gives you a power gain over a large straight collector,you are using too large of a size to begin with.
Keith
www.dunnuckracing.com
#1059734 - 08/23/11 11:33 AM Re: Merge Collectors [Re: 1967Valiant]
MR_P_BODY Online   content
Loc: Romeo MI
3 step
of .062
The collector I speced out was a standard straight...
as for a merge collector they are VERY specific to
each engine(sorta like a 2 stroke expansion camber)...
the cone rate dia and length then the small dia and
then the exit cone rate
W-9 8.94 @ 151 NOW ON E-85
Mike "Raff"...(180)Watching over us
CAR IS FOR SALE
#1059735 - 08/23/11 03:14 PM Re: Merge Collectors [Re: MR_P_BODY]
bumps440 Offline
super gas
Loc: Westbury, NY
Engine size? Rpm range?
P body..... do you use pipemax program???
Pipes seem a bit long to me.... Unless large motor and low rpms.
Well.... low by my standards.
446ci Iron heads, 3240lbs, Footbraker best et 9.84 @ 134.90 at sea level
#1059736 - 08/23/11 03:20 PM Re: Merge Collectors [Re: bumps440]
Loc: Romeo MI
Yes I use the Pipemax program.... have been for YEARS...
even when I built headers for Chrysler and had access
to the dyno to do testing
CAR IS FOR SALE
#1059737 - 08/23/11 03:32 PM Re: Merge Collectors [Re: MR_P_BODY]
bumps440 Offline
super gas
Loc: Westbury, NY
Recognized it right away. lol
I use it too. Have been for along time also. I dont build headers though. just use it to tune my projects.
Larry is a smart guy. and the program works if you use it right.
25,486 Registered Members
193,001 Topics
440 Six Pack Upper Fuel Line Leaks
by Ghoste
09/21/18 09:39 AM
Rear End Strength
by Nick Stevanovski
09/21/18 09:31 AM
Classic Industries Collector Car Insurance Program
by Rustymuscle
09/21/18 09:14 AM
cordoba front suspension?
by G code Jockey
09/21/18 08:43 AM
