Will a 426 Hemi fit in a 74 Charger? #1059676
08/22/11 11:04 PM
08/22/11 11:04 PM
FL
74-440Charger Offline OP
FL
Like to know if anyone has put the 426 hemi in a 74 Charger, right now it has a 440 between the fenders.
Re: Will a 426 Hemi fit in a 74 Charger? [Re: 74-440Charger] #1059677
08/22/11 11:08 PM
08/22/11 11:08 PM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
I dont see why not! isnt the engine bay of the 74 charger the same as an e body?.
Re: Will a 426 Hemi fit in a 74 Charger? [Re: moparsquid] #1059678
08/22/11 11:14 PM
08/22/11 11:14 PM
FL
FL
I'm not sure
Re: Will a 426 Hemi fit in a 74 Charger? [Re: 74-440Charger] #1059679
08/23/11 12:49 AM
08/23/11 12:49 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Here's a 73 Charger fortified with HEMI power, was featured in HOTROD some time ago
Re: Will a 426 Hemi fit in a 74 Charger? [Re: 74-440Charger] #1059680
08/23/11 01:25 AM
08/23/11 01:25 AM
wisconsin united states
K
keith airgrabber Offline
Right in the Nutz!!!
K
Yes it will fit. But the stock hemi oil pan will rub against the steering. You will have to either modify or go with a different pan.
Re: Will a 426 Hemi fit in a 74 Charger? [Re: DAYCLONA] #1059681
08/23/11 08:04 AM
08/23/11 08:04 AM
FL
FL
Looks good, but awful tight in there...
Re: Will a 426 Hemi fit in a 74 Charger? [Re: 74-440Charger] #1059682
08/23/11 10:35 AM
08/23/11 10:35 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Is there anything a HEMI isn't tight in?
Re: Will a 426 Hemi fit in a 74 Charger? [Re: DAYCLONA] #1059683
08/23/11 01:46 PM
08/23/11 01:46 PM
FL
FL
That's true...but I see that 73 doesn't have pwr brakes like mine does.
Re: Will a 426 Hemi fit in a 74 Charger? [Re: 74-440Charger] #1059684
08/23/11 05:14 PM
08/23/11 05:14 PM
Dalton, MA
Slipknot440 Offline
Slipknot440  Offline
Dalton, MA
you can always shoot for a small block 426 hemi. cheaper and more power
Re: Will a 426 Hemi fit in a 74 Charger? [Re: DAYCLONA] #1059685
08/23/11 05:24 PM
08/23/11 05:24 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Yep, tight in anything. As far as power brakes go, you'd likely have to use the Hemi only offset bracket from an earlier B body.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Will a 426 Hemi fit in a 74 Charger? [Re: 74-440Charger] #1059686
08/23/11 05:25 PM
08/23/11 05:25 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
think you can put 2 hemis crank to crank in that 71-74 engine bay.
MOPAR OR NO CAR
Re: Will a 426 Hemi fit in a 74 Charger? [Re: hemigod426] #1059687
08/23/11 05:40 PM
08/23/11 05:40 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
I had a 73 Rallye that ran around San Diego in the late 80's with a hemi in it. Other than the k-frame nothing else was modified in the engine compartment. It had power steering and brakes. It also was a big block car so the passenger inner fender had the large cutout, I am sure that was some help getting it in there.
Re: Will a 426 Hemi fit in a 74 Charger? [Re: 74-440Charger] #1059688
08/23/11 11:25 PM
08/23/11 11:25 PM
Middle TN.
4x4 Roundup Offline
4x4 Roundup  Offline
Middle TN.
It would have to fit...factory offered the Hemi in '71 and the platform is the same thru '74. No way could they change it...Richard was winning races with that car. Petty won more races w/the "coke bottle" Chargers (using a modified 340 small block) than any other set-up he had ever or since used. NASCAR even changed the rules so it could be used an extra year or so...[this info from one of his books]
WANTED-- DEAD or ALIVE:
'70 Duster--- VS29H0B274908-----UPDATE---ENGINE BLOCK FOUND---Still looking for the B-5 car.
'79 Power Wagon W14JE9S137761 or 763
Re: Will a 426 Hemi fit in a 74 Charger? [Re: 4x4 Roundup] #1059689
08/23/11 11:58 PM
08/23/11 11:58 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
Didn't '73 see the intro of the isolated K-frame and slightly different inner fenders? So they may have not been designed with the Hemi in mind as '71 was the last MY Hemi. If it fits in a '73, it must fit. But it sure looks from the picture like the valve covers hang over the frame rails. Might make going in from the bottom a bit of a chore.
Re: Will a 426 Hemi fit in a 74 Charger? [Re: MoparMarq] #1059690
08/24/11 10:39 AM
08/24/11 10:39 AM
Highland, Michigan
1972Rallye Offline
1972Rallye  Offline
Highland, Michigan
Absolutely right... No way would a Hemi fit from the bottom. It'll fit between the fenders, but it won't be a simple bolt in like it would be on a 71/72. The inner fenders on 73/74 are different from the 71/72 B-body (and E-body) inner fenders because of the suspension change, as mentioned.
I'm pretty sure the Petty cars didn't have inner fenders. Race cars were converted to have a tube type frame up front.
Re: Will a 426 Hemi fit in a 74 Charger? [Re: MoparMarq] #1059691
08/24/11 10:39 AM
08/24/11 10:39 AM
Middle TN.
4x4 Roundup Offline
4x4 Roundup  Offline
Middle TN.
I had a '74 (small block) and it did have the isolated K-frame which appeared to me to be simply large rubber bushings at the point of attachment to the sub-frame. I do not recall the inner fenders being different than on '71s, but, details do tend to fade over a 27 yr. span. As you stated if it fits a '73, it must fit [a '74]. I could never distinguish any appreciable difference in a '73 and '74.
Re: Will a 426 Hemi fit in a 74 Charger? [Re: 4x4 Roundup] #1059692
08/24/11 02:37 PM
08/24/11 02:37 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
If it'll fit in a Jeep CJ5,
it'll fit in a 74 charger with ease
Re: Will a 426 Hemi fit in a 74 Charger? [Re: gtx6970] #1059693
08/24/11 03:32 PM
08/24/11 03:32 PM
FL
FL
Thanks for all the replies, I may try it.
