Front end limiter #1059667
08/22/11 10:28 PM
08/22/11 10:28 PM
midwest
danbob Offline OP
danbob  Offline OP
midwest
Looking for a good way to limit front end travel.
Would like to make somthing that would be easy to adjust at the track.
Any input or pictures would be great. Thanks
Re: Front end limiter [Re: danbob] #1059668
08/23/11 02:03 AM
08/23/11 02:03 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
it's not easy to see in the pic but there's a covered link chain mounted on the underside of the bump stop & it's connected to the front strut. it maybe a bit rough but it works & it's adjustable. i just kept cutting out links til i got what i wanted. the front strut only holds the load of the t-bar so there's very little stress on that. i could have welded a tag on the lower control arm & one day that nmight happen if i upgrade to a tubular LCA.
