1/2" alum line to-an fitting
#1059631
08/22/11 09:32 PM
08/22/11 09:32 PM
Posts: 8,844 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
i ran new hard line up to the motor today because of space have to mount the filter under the car i bought the tube adapters from summit to go from hard to -an but i cant get it to compress is there something spossed to do?flare the end? i thought it was just a type of compression fitting the shank sticks out the nut right?
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
Re: 1/2" alum line to-an fitting
[Re: toplescuda]
#1059633
08/22/11 09:44 PM
08/22/11 09:44 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
the brass ferrel should crimp around the hard line when tightened. i spray a little wd40 on everything before i try tightening
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#1059634
08/22/11 09:55 PM
08/22/11 09:55 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
there hard line adapters sum-2200076 female-8 to 1/2"
[Re: toplescuda]
#1059635
08/22/11 10:00 PM
08/22/11 10:00 PM
sixpackgut
Charleston
yes, we know that. did you put the ferrel on after the nut?
[Re: toplescuda]
#1059637
08/22/11 10:09 PM
08/22/11 10:09 PM
Posts: 15,487 Florida
scratchnfotraction
a hard line to -an is a 3 piece compression fitting tube flare nuts are 2 piece fitting and you flare the hard line,and the shank sticks out the nut. hardline comp fitting has the red nut go on the hard line,then the copper ferrel ring,the the -an hardline adaptor as you tighten the red nut to the fitting it will compress the line and ferrel it was kinda hard when i did my line,I used the wood handle to tap the nut on the line then the ferrel the the adaptor taped on to start the threds you dont whant to run it till its out of threds so it can be open and resealed on that same ferel.
[Re: sixpackgut]
#1059638
08/22/11 10:09 PM
08/22/11 10:09 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
put nut on slid sleave inside with smaller section poking out the nut slid tube in till bottom out on the male -8 fitting there is no brass ferrel with this just nut and tube sleeve does the hard line have to be flared?
[Re: toplescuda]
#1059640
08/22/11 10:14 PM
08/22/11 10:14 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
ok didnt see the flare part part so i got to round up a flare tool or go buy 2 more stupid fittings
[Re: moparniac]
#1059642
08/22/11 10:31 PM
08/22/11 10:31 PM
sixpackgut
Charleston
you shouldnt need to flare it. the brass crushes around the line. thats it. put some wd40 on it. the aluminum sucks when trying to tighten compared to brass fittings
[Re: Cab_Burge]
#1059644
08/23/11 08:09 AM
08/23/11 08:09 AM
Challenger 1
Cincinnati, Ohio
crude but ya get the point...
Don't forget that ALL AN fittings are 37 degrees, not 45 degree like SAE are I would not put a brass ferrel on a aluminum line I did use a brass ferrule on a 1/2 inch soft drawn copper fuel line once, it work loose eventually
That's right, compression fittings are for sissys. They should only be used on hard line, like steel. Anything soft and they will leak for sure eventually. You can use a 45 flare tool, it will compress to 37 when tightened.
Sorry but copper or even aluminum is not the the best choice for fuel lines. It's too soft and can crack from vibration. BTW copper is for LP gas imo.
[Re: sixpackgut]
#1059646
08/23/11 12:21 PM
08/23/11 12:21 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
ok got it flared its on the suck side of the fuel system so no real pressure on it thanks guys
